Go to Post You have the rest of your life to play video games. Time at an FRC tournament is precious. Use it wisely. - gblake [more]
Unread 06-02-2003, 17:41
tareyton
Posts: n/a
Dump valve and pressure gage's
Last year we were required to have a dump valve and a pressure gage on the receivers but I can't find any of those requirements in this years rules. Does any one know if this is required this year and if so where it is stated
Unread 06-02-2003, 18:05
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
The relief valve you are referring to should be already attached to the compressor. It limits the output of the compressor to ~120PSI.
The regulator is required. Check the Pneumatics Manual and the last page of the Robot Manual for the checklist. The checklist states this, along with the pneumatics manual.
These are the only 2 things that are required for pneumatics. Everything else is optional, but you cannot use anything else other than what comes with the kit (other than the 3 cylinders in the order form).
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 06-02-2003, 18:30
tareyton
Posts: n/a
Dump Valve and Pressure gage
I am not refering to the relief valve on the compressor. I am refering to the bronze valve that last year we were required to have directly off the receiver to vent the system to atmosphere.
If you are storing vacumn in the receiver wont that screw up your regulator???
Unread 06-02-2003, 21:13
Go Badgers!
#0093
Re: Dump Valve and Pressure gage
Oh... that's called the Plug Valve... It's the 3-way bronze one with the black knob, right? It was never required to be in the line. It's more of a "convenience" thing. It's good for letting the air out easily. I highly recommend you put it on if you are pressurizing your pneumatics. More of a safety issue....
If you're planning on using the cylinder to generate a vaccum... then you don't need the regulator or the plug valve (because it'll never be hooked up to the compressed air loop)... the regulator is to limit the pressure to 60PSI.
pneumatic system pressure illumanat'i Pneumatics 6 31-01-2003 00:46
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
pressure sensors archiver 2001 0 24-06-2002 02:15
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
