Go to Post FIRST cannot enforce Gracious Professionalism on the participants in this program, you will have to do it on your own. - Ken Leung [more]
Unread 01-11-2013, 11:55
BurkeHalderman's Avatar
BurkeHalderman BurkeHalderman is offline
Casual Robot Observer
BurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant future
pic: Team 3266 Sheet Metal Drivetrain
Unread 01-11-2013, 11:56
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: pic: Team 3266 Sheet Metal Drivetrain
This looks really cool.
Hope to see pics once it is built
Unread 01-11-2013, 15:29
Jared's Avatar
Jared Jared is offline
Looks cool! How are the pulleys attached to the colsons and how thick is the sheet metal?
Unread 01-11-2013, 15:32
I am Dave! Yognaut
AKA: Brian Bray
My guess is that the pulleys are attached to the Colsons with this
Unread 01-11-2013, 16:20
Oblarg Oblarg is offline
AKA: Eli Barnett
Looks nice.
How are you handling the Colsons on dead axles? What size Colsons are you using? What pulleys are you using?
"The breakfast of champions!"
Unread 01-11-2013, 17:17
I am Dave! Yognaut
AKA: Brian Bray
My guess is this
Unread 01-11-2013, 17:41
We are using pulley stock and turning the end down to make our own pulley/hub that will press-fit into the Colson wheel. All the sheet metal is .100" aluminum.
The Colson wheels are the standard 4" diameter, 1.5" width. The pulleys press-fitted into the wheels are 28 tooth, 5mm pitch, GT2 profile pulleys, and the ones on the output shafts are 20 tooth.
You can see here the full wheel assembly with the hub, wheel and 3/8" flanged bearings, and on the right is the pulley hub that is machined from pulley stock.
[2010-2014]: FRC 3266 Robots-R-Us: Founder and Alumni
2010 (5-5-1): Buckeye Regional; Driver
2011 (4-5-0): Buckeye Regional; CORI; CAGE Match; Drivetrain/Manipulator Operator
2012 (7-13-0): Buckeye Regional; Queen City Regional; CAGE Match; BPRC; Drivetrain Operator
2013 (25-15-1): Queen City Regional; Buckeye Regional; Crossroads Regional; CORI; Ohio State Champs; CAGE Match; BPRC; Drivetrain Operator
2014 (21-10-0): Crossroads Regional; Queen City Regional; Designer; Mechanical/Design Mentor
Founding an FRC team as an 8th grader sure wasn't easy, but it was totally worth it.
Get in touch with me:
Personal Facebook
I believe every human has a finite number of heartbeats. I don’t intend to waste any of mine. – Neil Armstrong
Unread 01-11-2013, 17:59
AKA: Eli Barnett
Nice, I like that custom pulley design. Slick. No flanges?
Re: pulley stock, where do you buy yours? I bought some recently, and was dismayed at how expensive it is.
Unread 02-11-2013, 06:41
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Looks great!
One question for you though - how do you plan to mount bumpers? I have been practicing with sheet metal drive bases (my team plans to use one on a competition robot for the first time this year ) and I like the idea of having the flanges of the outermost panels bent outward but I'm not entirely sure how to mount bumpers securely.
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 02-11-2013, 09:45
No flanges?
We buy all our pulleys, pulley stock, and belts from SDP-SI. I agree the pulley stock is really expensive. At $60 for a 200mm bar I questioned if it was worth the cost to make our own hubs. Although the price drops a lot per bar the more you buy, which helps justify spending that kind of money.
I haven't put to much thought into mounting bumpers on this frame since it's just an offseason prototype, but I think what we'll do is something similar to 148's 2011 bumper system; put 1" hex standoffs in the corners and then use a uni-body bumper frame and bolt it to those hex standoffs. I'll CAD this and post a picture of it.
Here is a front view of the bumper frame and hex mount:
Personal Facebook
Unread 03-11-2013, 12:48
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (WildStang)
Team Role: CAD
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
You loss a bunch of strength when you don't have the belly pan under the CIMs. try to fit the CIMs so the belly pan isn't cut out. Anyways, great job, looks like a good start to a great bot.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 04-11-2013, 09:50
jeremy callahan's Avatar
jeremy callahan jeremy callahan is offline
FRC #5053
jeremy callahan will become famous soon enough
I'm sorry idk if you already answered this or not i didnt see it if you did. I was wondering what the thickness of the metal was and is all the metal machined or did you get any of it assembled for you? looks awesome to see the finish product!
Unread 04-11-2013, 10:13
All the metal is .100" aluminum and is cut out using a laserjet and then bent on an automatic break, this is done by one of our machining sponsors. Then the students rivet the frame together.
As far as the overall design I owe a lot to the guys from 2168 and 228. Without their generosity and CAD files I wouldn't be anywhere near a production ready sheet metal drivetrain. Also the design for the pulley hubs was originally from 2168's 2013 robot and the weight reduction is heavily influenced from their 2011 base. What can I say I'm a huge fan!
Personal Facebook
Unread 04-11-2013, 11:06
AdamHeard's Avatar
Lead Mentor
$60 for an entire drives worth of pulleys isn't crazy at all.
Unread 04-11-2013, 11:28
Well it's actually about $230 total for all the pulley stock needed for the drive as we need 4 200mm bars of pulley stock. I only have experience using small belts on manipulators, nothing to this scale before, so i dont know if that price still a reasonable amount to spend on this drive?
Personal Facebook
