Go to Post “I hope you all had a good weekend. If you didn’t you can try again in five days.” -Honors Debate teacher - Joe J. [more]
Unread 05-11-2013, 18:26
Chris is me's Avatar
AKA: Pinecone
Re: FRC Team Spotlights #2: 67 "The HOT Team"
Originally Posted by Brandon1266 View Post
Ah alright something felt a little iffy at that part but I get what you're saying after I watched a couple more times. It's still pretty cool though that their robot didn't just fall off the ramp all together and get damaged though. Thanks.
67's hanging arm was very cool. If I remember correctly, the gas springs it relied on were mechanically released when the arm latch was deflected by the bar of the tower. Once the claw is released from the top it's all passive and requires no robot power. The claw latch was one-way, so once secured it basically couldn't let go of the tower. Possibly one of the most inspirational mechanisms I've seen in FRC, right up there with everything else 67 has ever done.
Unread 05-11-2013, 22:37
brandon.cottrell's Avatar
brandon.cottrell brandon.cottrell is offline
Vice President
FRC #1266 (The Devil Duckies)
brandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud of
I couldn't have said it better myself.
Unread 06-11-2013, 15:57
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Technically, the arm that grabbed the tower was velcroed to a latch that was released by a servo. Once the servo was released, as the arm and latch opened it pulled a bike cable that routed to a trunk latch that held the gas springs that once released would pull the rope and lift the robot. The cable was pulled about mid-swing to release the springs. When the arm hit the tower it would detach and only be connected to the robot by the rope.
Similar to this past year, the robot did not start the season with the hanger on the robot. So, no hanger at all at Kettering. We started installing it at Detroit. It started working correctly at MSC. And was finally needed to win in Atlanta.
It was not an easy system to get working. There was a ton of iteration and trial and error to get the timing and positioning right. Throughout the season everyone kept telling us to forget about getting it working and focus on just scoring a couple of more balls.
Luckily we did not listen and all our hard work finally paid off in that Finals 1 match.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
