Go to Post Even as a "mentor", I am still being mentored by engineers who work with the team. - Tom Bottiglieri [more]
Unread 06-11-2013, 10:48
DocMartin DocMartin is offline
FTC #6285
DocMartin is an unknown quantity at this point
[FTC]: Field Hardware USB hub
WE have a field that is permanently set up. We have FCS working fine, however, We would like to set up the Controllers using the USB Hubs just like in Competitions. Is there a parts list for setting up the field?
Unread 06-11-2013, 18:32
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Re: [FTC]: Field Hardware USB hub
Per alliance station, you'll need the following:
1 Powered USB hub (Needs to be powered, I recommend a 7 Port Hub)
4 Logitech controllers (F310, with the switch on the bottom set properly)
1 USB Extension cord (Preferably with a repeater)
You ought to be able to find all the parts you need at OfficeMax, BestBuy or Radioshack. Good luck. And if you need any further tips, let me know.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 12-11-2013, 22:59
FTC #6285
sounds easy enough I ordered the USB cables and hubs online good pricing @ showmecable.com
Unread 15-11-2013, 21:30
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Here in Florida we have 5 Leagues that each has a "tournament in a box" which is all of the field electronics in a box ready to set up a tournament in a matter of minutes. This is the hub and cables we use for the setup.
http://www.amazon.com/7-Port-USB-2-0.../dp/B000KUQ8FG
http://www.monoprice.com/Product?c_i...seq=1&format=2
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
