Go to Post Kyle from team 45 said "Dude, I still have 2 years left in FIRST ahahaha.." My response to that was... "Kyle, I have till the day I die." - Arefin Bari [more]
Unread 06-11-2013, 20:40
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Get Pneumatic Pressure
Is there a way that the robot can read that pneumatic pressure from the pressure switch and then send that feedback to the smart dashboard?
Unread 06-11-2013, 22:01
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: Get Pneumatic Pressure
The pressure switch is a digital switch and doesn't directly send the air pressure directly to the cRIO. I don't believe it is possible to read the air pressure without a separate sensor.
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 06-11-2013, 23:25
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
You don't have to add an additional sensor just calibrate the sensor for many different pressures, fit a function to these data points, and use that function to determine what the pressure is in the system. Most of this can be done in any spreadsheet program.
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 07-11-2013, 00:27
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
The pressure switch is just that, a switch, and not a sensor. It is commonly called a binary switch since it has a built in hysteresis. The circuit opens at ~115 psi and will not close again until the pressure drops to ~95 psi. So if you want to know the pressure you will need to instal a pressure sensor.
Unread 07-11-2013, 06:31
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
The Pressure Switch is connected to the Digital Sidecar therefore i thought you would be able to read the pressure that it is sensing. We wanted to know how much air we have in our tanks during the match.
Unread 07-11-2013, 08:05
The Q&A responded to pressure transducers last season...
Q428 Are pressure transducers (analog pressure sensors) legal for use on the high pressure side of the pneumatic system, in addition to the standard pressure switch used to control the compressor? Assuming that all specification (maximum pressure, etc) are met.
A: No Please see R82.
Please check the rules for this season for any changes.
Unread 07-11-2013, 18:57
DonRotolo's Avatar
Back to humble
FRC #0832
Sorry to be brutal, but you thought wrong. It is a switch. It is either on or off. Nothing more.
Unread 07-11-2013, 20:11
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Two suggestions:
1) Mount some type of pressure sensing device for practices, practice a ton while carefully studying the pressure results you are interested in then remove the device for competition, but use the data.
or
2) Mount your high-side pressure gauge in an area that it can be seen by your axis camera and read the pressure on your driver station laptop.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 07-11-2013, 20:25
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
The Pressure Switch (http://www.andymark.com/product-p/am-2006.htm) reads the air pressure in the system and tells the shuts off the compressor when 120 psi is hit by communicating with the Digital Sidecar. That is why you specify the relay and digital input output port when coding. The relay is for the compressor and the DIO is for the switch that gives a reading and shuts off the compressor when that reading hits 120 psi. I have seen other teams read the psi using that but i wanted to know how we can do it the same way.
Unread 07-11-2013, 20:33
Here's the data sheet for the pressure switch: http://files.andymark.com/NasonSMspecs.pdf. Each sensor is factory preset to a certain PSI that can't be changed. It only outputs a digital/binary signal; it does not report the actual pressure to the cRIO.
Unread 07-11-2013, 23:57
Have you looked at the methods for the compressor class?
Unread 08-11-2013, 06:57
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Thank you Joe! I don't know why I didn't start there but I found a way to do it. Thanks.
Unread 08-11-2013, 08:16
Everyone, please understand that the 120 psi specification is not a hard spec. In my experience (watching during inspections) it is more likely 120 +3/-5 psi from unit to unit.
Unread 09-11-2013, 00:51
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I wonder if it's the right time of year for the GDC to consider a 2014 rule allowing any pressure sensor rated for the pressure in the system at that point of installation. (If it would replace the switch, it would have to be rated against all failures; if it would supplement the switch, non-operation is not important, so it would need only be rated not to be pneumatically compromised in normal service.)
