Go to Post I never cease to be amazed at the creative engineering employed by some teams. - Karthik [more]
Unread 09-11-2013, 12:27
Happy Birthday! Zaque Zaque is offline
FF: Bobo Brigade
AKA: Zachary H.
FRC #3352 (Flaming Monkeys)
Zaque has a spectacular aura aboutZaque has a spectacular aura aboutZaque has a spectacular aura about
Invert Motors in Java
Hello,
We are switching from LabVIEW to Java for the coming build season, and we are currently rewriting our 2013 code in java. We have everything working except for the driving. In the LabVIEW program we had, our front and rear left motors inverted. I have looked at other posts using RobotDrive.setInvertedMotor, but I have not been able to get the program to accept it. My code is attached:
/* Copyright (c) FIRST 2008. All Rights Reserved. */
/* Open Source Software - may be modified and shared by FRC teams. The code */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project. */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.AnalogChannel;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.Timer;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the SimpleRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public class RobotTemplate extends SimpleRobot {
Victor frontLeft = new Victor(1);
Victor rearLeft = new Victor(3);
Victor frontRight = new Victor(2);
Victor rearRight = new Victor(4);
/**frontLeft,rearLeft,frontRight,rearRight**/
RobotDrive chassis = new RobotDrive(frontLeft,rearLeft,frontRight,rearRight );
chassis.setInvertedMotor(RobotDrive.frontLeft, true);
chassis.setInvertedMotor(RobotDrive.rearLeft, true);
/**pressureSwitchChannel, compressorRelayChannel**/
Compressor compressor = new Compressor(1, 1);
/**channel**/
DoubleSolenoid right = new DoubleSolenoid(2, 1);
DoubleSolenoid left = new DoubleSolenoid(4, 3);
/**channel**/
AnalogChannel pot = new AnalogChannel(1,1);
Victor shooter = new Victor(8);
Victor angle = new Victor(10);
Victor loader = new Victor(9);
Joystick driver = new Joystick(1);
Joystick operator = new Joystick (2);
double v;
int i = 0;
boolean lastPress = false;
boolean currentPress = false;
boolean shooterState = false;
boolean lastPress2 = false;
boolean currentPress2 = false;
boolean solenoidState = false;
public RobotTemplate() {
compressor.start();
public void autonomous() {
chassis.setSafetyEnabled(false);
shooter.set(100);
v = pot.getVoltage();
/**set angle**/
while(v < 1.43){
angle.set(1);
angle.set(0);
/**fire**/
while(i<6){
Timer.delay(0.5);
loader.set(100);
Timer.delay(0.25);
loader.set(0);
i++;
shooter.set(0);
* This function is called once each time the robot enters operator control.
public void operatorControl() {
chassis.setSafetyEnabled(true);
while(isOperatorControl() && isEnabled()){
/**drive code**/
chassis.arcadeDrive(driver.getRawAxis(1), driver.getRawAxis(4));
/**hanger code**/
lastPress2 = currentPress2;
currentPress2 = driver.getRawButton(9);
if(currentPress2 && !lastPress2){
if(solenoidState){
left.set(DoubleSolenoid.Value.kForward);
right.set(DoubleSolenoid.Value.kForward);
}else{
left.set(DoubleSolenoid.Value.kReverse);
right.set(DoubleSolenoid.Value.kReverse);
solenoidState = true;
/**shooter toggle code**/
lastPress = currentPress;
currentPress = operator.getRawButton(2);
if(currentPress && !lastPress){
if(shooterState){
shooter.set(0);
}else{
shooter.set(1);
shooterState = true;
/**loader code**/
if(operator.getRawButton(5)){
loader.set(1);
}else{
loader.set(0);
/**angle code**/
if(operator.getRawButton(1)){
angle.set(operator.getRawAxis(2));
}else{
angle.set(0);
Timer.delay(0.01);
* This function is called once each time the robot enters test mode.
public void test() {
Zaque (Zach) H.
President
Programming/Electrical Lead
Unread 09-11-2013, 13:06
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: Invert Motors in Java
The RobotDrive#setInvertedMotor() method takes a RobotDrive.MotorType object as the first parameter instead of a reference to the actual motor. Try using this:
chassis.setInvertedMotor(RobotDrive.MotorType.kFrontLeft, true);
chassis.setInvertedMotor(RobotDrive.MotorType.kRearLeft, true);
Also, don't forget that the joysticks treat forward motion along the X axis as a negative value, whereas the RobotDrive treats a positive value as forwards movement (I think; could someone else confirm this? It may depend on your setup). You may want to negate your X axis reading as well.
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 09-11-2013, 13:20
FF: Bobo Brigade
AKA: Zachary H.
When I put that in the code, I get the error:
package chassis does not exist
<identifier> expected
cannot find symbol
symbol: class kFrontLeft
illegal start of type
Zaque (Zach) H.
President
Unread 09-11-2013, 13:50
Make sure those two lines are inside either the robotInit() method or the constructor
public void robotInit() {
or
    compressor.start();
Unread 09-11-2013, 15:14
FF: Bobo Brigade
AKA: Zachary H.
That solved it. Thanks for your help.
Zaque (Zach) H.
President
