Go to Post The propagation of the idea of making FIRST into a perfectly fair competition is just silly. - Andy Baker [more]
Unread 07-11-2013, 19:49
sergioCorral842's Avatar
sergioCorral842 sergioCorral842 is offline
College Student
FRC #0842 (Falcon Robotics)
sergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to behold
Driver Station/ Connection Issues
So today, while I was teaching someone how to drive our robot, something strange occurred. The robot code light blinked at a constant rate from green to red and the "No Robot Communication" message also appeared and went away at the same constant rate.
Also, I have not changed the code on the robot since nationals and it has been working fine until today. I think it is an issue with the bridge but I am not entirely sure. Any suggestions would be appreciated.
Team 842 Falcon Robotics: 2011-2015 (President, Head Programmer, Drive Team)
Arizona Regional Winners: 2012-2014 (Thanks 610, 1212, 1726, 3944, 2486, 2403)
Curie Division Semi-Finalists: 2014 (Thanks 1311, 2013, 2928)
Las Vegas Semi-Finalists: 2015 (Thanks 3495, 4415)
Curie Division Quarter-Finalists: 2015 (Thanks 107, 228, 649)
2015 - 2016: Programming, Drive Team, and Strategy Mentor for Team 3187, The Titans
Studying Computer Science- Software Engineering at ASU (Class of 2019)
Unread 07-11-2013, 20:58
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Re: Driver Station/ Connection Issues
Not the same indicators - but we recently had situations where the robot would not respond to driver controls perfectly - even times in matches at THOR where it died on the field (Field techs had trouble setting it up in bridge mode too). We replaced the bridge and it worked perfectly for IROC...(other things went wrong though...naturally).
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 09-11-2013, 21:07
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
You can try resetting your radio using the FIRST provided bridge configuration utility. I've noticed that radios that don't operate properly usually don't program properly either.
If you still have issues you can try upgrading/restoring the firmware on the radio to version 2.03.
Unread 16-11-2013, 08:54
Shmuel Shmuel is offline
FRC #4817
Shmuel is an unknown quantity at this point
My team(4817) is having the same exact issue. The robot code light is flashing at a constant rate. This problem appeared randomly when we were driving the robot. So far we have:
1. Tested for electrical noise by adding capacitors to the wires leading to the router.
2. Reimaged the cRIO
3. Reimaged our Classmate
After trying all of this the robot would still not work reliably on WiFi. One thing that we did notice is that when we tethered the robot it would solve this issue. Please let me know if you find a way to solve this problem.
