Go to Post Start respecting your mentors more or they might just leave. - Eric Bareiss [more]
Unread 15-10-2013, 17:11
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Laser Cutter Suggestions
Hello,
Our team was recently looking into getting a small laser cutter after seeing the one sold by buildyourcnc.com. After talking to the engineering teacher at our school, we were happy and surprised to hear that the school had already purchased one of these kits for the engineering classes however, after a emailing the buildyourcnc tech support we found out that the blackTooth's CO2 laser doesn't cut metal. While we can still use it on wood and plastic, I wanted to investigate a little further and see if any teams knew of a system of similar size (this one is 20x24 which was nice because we don't have a large storage space) that was capable of cutting metal. Thanks
-Jesse
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 15-10-2013, 17:17
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Laser Cutter Suggestions
Originally Posted by MetalJacket View Post
Hello,
-Jesse
I think you'll have a hard time finding a machine at a reasonable price or size to cut metal. Most metal cutting lasers are targeted at industrial workplaces, and are designed to cut full size 4x8 sheets of metal. Not to mention the wattage required will usually be four figures, which requires some pretty hefty industrial power.
This is the smallest metal cutting laser I've ever seen: http://www.hurricanelasers.com/betty
There are plenty of uses for a low-power laser system in FRC though. We make plenty of delrin parts and wood/acrylic prototypes with a machine owned by a local college.
Unread 15-10-2013, 17:21
AKA: Jesse Gibson
Team Role: CAD
I kind of figured that going up to the higher class laser would have a corresponding price jump, but just wanted to double check. Targeting industry makes sense too. Thanks for confirming
2011 - Logomotion
Unread 15-10-2013, 22:58
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Maybe Adam can weight in but I thought 973 used laser cut (or was that cnc router?) baltic birch. There is a large chunk of the robot that can be made with wood and plastic.
If you want laser cut metal,your best bet would be to find a shop to do it. Our laser cutting sponsors are pretty easy going because we knock out all our parts in one go.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 15-10-2013, 23:14
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Routered for sure, those guys router like monsters!
-RC
R.C.
MadTown Robotics Team 1323
Unread 15-10-2013, 23:58
FRC #1836 (MilkenKnights)
-RC
For sure. They router a ton of wood and metal. They even router their hole pattern so they don't have to do it manually.
Unread 16-10-2013, 00:07
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
We just got training on the school's new Universal Laser VLS3.50. The training rep said the rule of thumb is about 10W/0.1" of material thickness for acrylic and light woods.
Unread 10-11-2013, 10:43
Oblarg Oblarg is online now
AKA: Eli Barnett
There's a lasercutter in the lab I work in which 4464 is making good use of. No, it can't cut metal, but honestly if you're creative and you know the properties of your materials, it's surprising the number of things you can do without metal. We mainly use it for delrin, and it's incredibly useful. Sure, it'd be nicer if we could CNC metal parts, but we're doing some pretty cool stuff with delrin.
"The breakfast of champions!"
Unread 10-11-2013, 11:56
yash101 yash101 is offline
AKA: null
This makes me think that even though our team is gifted so many neat tools, like three 3D printers, Laser-cutting machine, 6-axis CNC (upon request), CNC router, all these amazing tools. We have used the 3D printer a couple of times, but nothing much, otherwise.
Unread 11-11-2013, 11:28
eli2410's Avatar
eli2410 eli2410 is offline
Alumni/UCF Student
FRC #2410 (Metal Mustangs)
eli2410 is a glorious beacon of lighteli2410 is a glorious beacon of lighteli2410 is a glorious beacon of lighteli2410 is a glorious beacon of lighteli2410 is a glorious beacon of lighteli2410 is a glorious beacon of light
You could use Cermark, mark where you want to cut with it (engraves without destroying laser, comes out black) and then cut the lines with a band saw or something else.
Co-captain:
2013: Cowtown Throwdown-Winners
2014: Greater KC Regional-Judges Award & Oklahoma Regional-Judges Award and Dean's List Finalist (Lauren Pudvan)
Team Member:
2013: Razorback Regional-Team Spirit & Woody Flowers (Mr. Ritter) & Greater Kansas City Regional- Gracious Professionalism
2012: FIRST Championship in St. Louis, Oklahoma Regional- Team Spirit Award, & Greater Kansas City Regional
2011: Midwest Regional & Greater Kansas City Regional- Innovation in Control
Little Brother (Spectator):
2008: FIRST Championship in Atlanta & Greater Kansas City Regional
Unread 12-11-2013, 16:59
AKA: Jesse Gibson
Team Role: CAD
That is a really interesting idea that I hadn't considered before. Thanks!
2011 - Logomotion
Unread 12-11-2013, 22:29
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Delrin always melted well before it even cut through the last time I tried laser cutting it. ABS worked really well though. Are you sure you got delrin to work?
Unread 12-11-2013, 23:26
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Then try less power and more speed with more passes. You usually need to do multiple passes laser cutting, especially on lower wattage machines.
By the way, I've heard that laser cutting ABS produces toxic Styrene gas. I probably wouldn't laser it any more before making sure.
-Plutarch
Unread 13-11-2013, 00:01
AKA: Eli Barnett
In the lab I work in the vast majority of our CNC'd robot parts are lasercut delrin. So, yeah, it works.
Turn the power down low, do multi-pass if you have to (on 1/4'' delrin, we usually do 3-4 passes). I don't know what model lasercutter you have, but I can stop by the lab and tell you the specs on ours and the standard settings for various thicknesses. We can get up to about 1/4'' thick before the melting starts to get unacceptable for our required precision.
Make sure you have a nice exhaust system set up so you're not breathing in any of the fumes, though.
Unread 13-11-2013, 00:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Delrin cuts nice. ABS smells really bad, and I wouldn't recommend it for laser cutting.
