Go to Post You never know when the GDC will slide in a rule about any robot with a laser must do a laser light show on the floor of the field or face a 50-point penalty :p. - EricH [more]
Unread 31-10-2013, 11:12
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
Connecting to the robot - C#
Hello,
I've been trying to use NetworkStream in C# to connect to the robot, but I can't find a good resource to help me recieve packets from the robot. I've got the labview code that will run using TCP but I'm needing some help on the client side.
Anyone Know C# well enough to help, or at least point me to the right resource?
Thanks!
Per Audacia Ad Astra
Unread 31-10-2013, 16:33
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Connecting to the robot - C#
You should just call NetworkStream.Read, but it sounds like you've already made it that far. What exactly isn't working?
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 01-11-2013, 09:26
It never actually connects to the robot to get any data:/
Unread 05-11-2013, 17:34
Have you looked into the TcpClient class?
Team 973 (2016-???)
日本語でOK
Unread 05-11-2013, 21:00
I have not, do you have any good resources you can give me on that?
Unread 05-11-2013, 23:07
MSDN is the place to go for C#. There are some examples further down.
Team 973 (2016-???)
日本語でOK
Unread 05-11-2013, 23:26
I can't believe I didn't think of MSDN before, I guess my version of VS doesn't have in implemented because I got Express 2012:/
Thanks!
Unread 09-11-2013, 09:21
Post Re: Connecting to the robot - C#
I've got a small labview program writing a string to the stream and then on the client side (written in C#), when I read the stream every 20ms, it comes back jumbled after the first read.
For instance, if I wrote a string "a b c" to the stream, it would read like this for the first four iterations (each line is what is read at 20ms):
"a b c"
" ca b"
"b ca "
"ca b "
As you can imagine, this is very annoying if I'm splitting up the string on the client side and using the three numbers for calculations.
Do I need to change the speed at which I'm reading the string or what's causing the inconsistency?
Unread 10-11-2013, 12:19
Fifthparallel Fifthparallel is offline
AKA: Sam Chen
FRC #1410
Fifthparallel is an unknown quantity at this point
Can you post a screenshot of your LV server you have running and copy/paste some of the C# you're using?
sudo chmod u+x helloworld.sh
gotta start somewhere.
Unread 12-11-2013, 22:17
Yep!
Here's the server code, really simple LV server, went off a youtube tutorial
Here's the C# code to read the stream, note that this reads every 20ms.
 private void timUpdate_Tick(object sender, EventArgs e)
            //update revolutions X and Y and the Gyro Angle every 20ms from the server string value
            //and make sure the connection is solid, otherwise update connection
            Byte[] info = new Byte[Client.ReceiveBufferSize];
            try
                int rData = stream.Read(info, 0, System.Convert.ToInt32(Client.ReceiveBufferSize));
                RobotData = System.Convert.ToString(rData);
            catch (System.IO.IOException)
                lblConnectInd.BackColor = System.Drawing.Color.Red;
                Log("The robot ended the stream.");
                stream.Close();
                Client.Close();
            //split string into X, Y and angle
            strRevX = RobotData.Substring(0, 2);
            strRevY = RobotData.Substring(5, 2);
            strAngle = RobotData.Substring(8, 2);
            //update values recieved in GUI
            lblX.Text = strRevX;
            lblY.Text = strRevY;
            lblAngle.Text = strAngle;
            //convert separated strings into doubles
            Double.TryParse(strRevX, out dblRevolutionsX);
            Double.TryParse(strRevX, out dblRevolutionsY);
            Double.TryParse(strAngle, out dblAngle);
            //make sure we're still connected
            if (Client.Connected == true)
                lblConnectInd.BackColor = System.Drawing.Color.Green;
            else
                timUpdate.Stop();
Other than the jumbled string, it works great!
