Go to Post I am allergic to work... - Mike Schroeder [more]
Unread 05-11-2013, 16:46
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
pic: The RoboBees' 2015 Control System Alpha Testing Progress
Unread 05-11-2013, 16:55
tim-tim's Avatar
AKA: Tim Miedzinski
Re: pic: The RoboBees' 2015 Control System Alpha Testing Progress
For more information about the process please check out our website, specifically our Alpha Testing Blog.
The first photo is the "electronics board" prior to being installed on the robot. There are still a few wires that needed to be terminated on the robot once installed. The top right picture provides a quick glimpse of what the control system looks like from the front of the robot. The shooter is removed for clarity. The bottom right picture shows the fully assembled robot that was placed in the crate Sunday.
For more pictures, be sure to check out the blog.
Let us know if you have any questions.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 05-11-2013, 18:05
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
what's the IDE cable go to?
Unread 05-11-2013, 18:44
tim-tim's Avatar
AKA: Tim Miedzinski
Are referring to the connection port near the center of the roboRIO? If so, it is our understanding that FIRST and NI are leaving that available for teams to further develop. There are extra DIO, PWM, Analog In, etc connections that can be tapped into by teams, if desired.
If you are referring to the D-Sub connector just beside the PD board, that is our sensor connection point for our shooter.
We will have back-to-back workshops at VCU on Saturday 23 Nov, if you would like to see the system up close and in person.
The RoboBees
Unread 05-11-2013, 22:42
wilsonmw04's Avatar
Coach
It's the green connector. It's not an IDE, sorry, it's an old parallel printer cable. OR that's what it reminds me of. My team is running a session as well @ VCU. I will make it a point to poke my head in and take a closer look. I should be a fun day
Unread 06-11-2013, 06:29
tim-tim's Avatar
AKA: Tim Miedzinski
The green connector is a 50 pin D-Sub connector that we are using as our "quick connect" for sensors between the electronics board and the shooter. We are able to drop the electronics board by removing 4 screws from underneath the robot and disconnecting the D-Sub, a few Anderson PowerPole connections, and a few other wires. Similarly, this gives us the ability to remove the shooter by removing 8 screws, the D-Sub, and a few Andersons.
You can buy them from Mouser Electronics, or plenty of other places in the web. We look forward to seeing you there.
The RoboBees
Unread 08-11-2013, 14:16
philso philso is offline
FRC #2587
Here is a link to an article about the roboRIO that a co-worker just sent me
www.nxtbook.com/nxtbooks/hearst/ep1113/#/26
Unread 08-11-2013, 14:25
tim-tim's Avatar
AKA: Tim Miedzinski
Can you check the link? I could not get it to work on my end.
-Tim
The RoboBees
Unread 08-11-2013, 14:28
http://www.nxtbook.com/nxtbooks/hearst/ep1113/#/26
pntbll1313's Avatar
pntbll1313 pntbll1313 is offline
2052 Coach, Build/Electrical Mentor
AKA: Pete
FRC #2052 (KnightKrawler)
pntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud of
-Tim
It looks like his hyperlink didn't work. Just copy paste it. Or try this www.nxtbook.com/nxtbooks/hearst/ep1113/#/26
2016 (mentor/drive-coach)
Quarter-Finalist-Einstein, Winner-Carson Division Champs, Winner-10K Lakes, Chairman's Award-10K Lakes, Finalists-Lake Superior,
Winner-MSHSL Robotics Competition
2015 (mentor/drive-coach)
Finalists-10K Lakes, Finalists-Lake Superior, Finalist-MSHL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2014 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior Winner-MSHSL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2013 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior, Winner-MSHSL Robotics Competition, Quarter-Finalist-Newton Division Champs
2012 (mentor/drive-coach)
Finalists-Lake Superior, Semi-Finalist-MSHSL State Championship, Semi-Finalists at 10,000 Lakes
2008-2011 (college mentor)
2007 (driver)
Quarter Finalist-Milwaukee
Unread 10-11-2013, 11:51
yash101 yash101 is offline
AKA: null
Question Re: pic: The RoboBees' 2015 Control System Alpha Testing Progress
I wish we could be a beta-testing team! How'd you guys become one of the beta-testers? But great job! Looks great!
Unread 10-11-2013, 20:32
tim-tim's Avatar
AKA: Tim Miedzinski
To be honest we do not know how we were selected to conduct Alpha testing this year. We have some ideas, but we do not know any of the selection criteria.
As far as Beta Testing goes, FIRST will send notify teams usually through an email blast for the application process. This year, FIRST sent out this Email Blast requesting all teams interested in participating in 2014 Beta Testing to complete a survey.
Again, we are doing Alpha Testing, which to our knowledge did not have a public registration period; Beta Testing is something you must apply for.
Thanks for the positive comments. Let me know if you need any further clarification.
The RoboBees
