Go to Post Sooo....in the famous words of Douglas Adams, Don't Panic. - Conor Ryan [more]
Go Back   Chief Delphi > Technical > CAD
Unread 12-11-2013, 14:59
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
New prototype transmission design
http://i.imgur.com/3VsZEJA.png
Starting to make the parts now. Looks promising so far
Unread 12-11-2013, 16:35
Nate Laverdure's Avatar
FRC #2363
Re: New prototype transmission design
Very minimalist and clean, but how are you reacting against the large axial (thrust) loads on the worm gear?
Unread 12-11-2013, 22:49
FRC #1658
there is a thrust bearing between the cim face and warm on one side and a ball bearing on the opposite supported by 1" by 1/4" plate. The ball bearing may be an issue but we'll give it a try and if need be it will be simple enough to fix anyway. the ball bearing can be replaced with a tapered roller bearing or can just add a thrust bearing on top of the ball bearing and adjust the spacer accordingly. So not really an issue even if it does become an issue since it's very easily fixed. As stated its still a prototype =p
Unread 12-11-2013, 23:45
T^2 T^2 is offline
FRC #5499
How is this to be implemented? Will the modules be arrayed in a holonomic or tank style?
One issue I see is that the only thing that stops the axle pulling out of the back bearing is a dinky little retaining ring. Correct me if I'm wrong.
Also, you could save a lot of weight with a bit of pocketing on your plates.
Unread 13-11-2013, 01:55
FRC #1658
It's a holonomic setup where we have one transmission in each corner of the robot. that part of the design isn't new and had great success with it the past few years. But as you stated could use it on two opposite corners for tank drive or with a straight plate can use it for any other drive as well.
You are correct about the retaining clip, but we've used this same axle configuration last year and never had a single problem with it so as far as i'm concerned it's not an issue. We have a bolt on one side for easy dissasembly(which is a maintenance item and even though we used lock washers we did need to keep checking that they are tight so wheels didn't fall off) but it's worth the ease of access.
While we could reduce the weight a marginal bit by pocketing the plate or making the blocks smaller I don't think it's worth it. The plates provide most of the rigidity of our chasis so pocketing them could compromise structure too much. As it is currently with all the changes(compared to last year), this complete drive chasis(with wheels) should weigh around 20-25lbs which is almost half of what ours weighed last year and most of that weight is the cims.
I mean once you take into consideration what we have here(a 10:1 transmission) ready to be bolted onto the chassis with wheel already attached, it's one of the lightest setups you can have when you take mounting and other interfacing hardware into account of other drive systems.
