Go to Post FIRST has a 365 day season (366 on leap years)... - Adam Richards [more]
View Poll Results: Did your team finish their chassis in 1 hour
Yes 7 15.22%
No 39 84.78%
Voters: 46. You may not vote on this poll
Unread 25-01-2003, 23:11
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Our bot was rolling by the end of week two and driving by last thursday. We used one of the aluminum tube and other 1/4" aluminum sheets. I hope we can stay under weight though, our frame and drivetrain weigh about 60 pounds.
It is pretty sweet, we also got our full size ramp on wednesday so we got a chance to drive over a couple times. One of our joysticks calibration won't work so we have to get FIRST to get us a new one.
We start work on our arms tommorow. This has been our 4th or 5th idea for our arms and I hope we stick with it. GO RAIDERS!
Unread 25-01-2003, 23:27
HolyMasamune's Avatar
HolyMasamune HolyMasamune is offline
41246017 O-('_'Q)
AKA: Y C
None #0840 (Aragon Robotics Team)
HolyMasamune is on a distinguished road
Send a message via AIM to HolyMasamune
A very basic chassis that takes nothing into consideration can be done pretty easily, but a chassis that is suitable for fitting all the stuff that needs to be on the robot takes much longer.
Unread 25-01-2003, 23:43
GregTheGreat's Avatar
GregTheGreat GregTheGreat is offline
GregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura about
The Kickoff Time
I think that it took the engineers at the kickoff a lot longer than an hour.
I think they came in with someparts pre done, along with an extensive know-how of the parts and how to build it quickly.
They said they had some holes pre-drilled. I still think that they knew how to build it before hand. I think that it takes longer for us to build the robots because we did not know the parts, and had to actually take the time to work with it and figure it out.
Hey on the other hand, at the kickoff all the bots didn't work anyway. LOL
Good Luck Every1
-Greg The Great
Unread 26-01-2003, 01:23
yangotang's Avatar
yangotang yangotang is offline
#0253 (MRT)
yangotang is on a distinguished road
Send a message via AIM to yangotang
I still think that "Full Chassis In One Hour" thing is flaud.
It takes me 1 hour to drill two holes, as my teacher-moderator said.
Unread 26-01-2003, 03:51
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
If you are using 80/20 or Bosch extrusion, you can very easily put together a frame in one hour. However, cutting the extrusion, and milling the ends (helps make it perfectly square) takes a lot longer. Update on our status: As of Thursday, we had the bas level and two wheels mounted. As of today: we have the base level and four wheels mounted... Shows our progress eh
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 26-01-2003, 16:05
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
We had to rebuild our chassis because the original one had been welded incorrectly. It took four hours for 3 programmers to cut and drill it.
Unread 26-01-2003, 16:08
Duke 13370's Avatar
Duke 13370 Duke 13370 is offline
C is for cookie...
#0862 (Team Lightning)
Team Role: Webmaster
Duke 13370 will become famous soon enough
Send a message via AIM to Duke 13370
our chassie isn't exactly the same as the cookie cutter one, but it still took us 4 hours and we are less than half done.
---Lightning Robotics!---
Unread 07-02-2003, 10:01
mooveitrobot420 mooveitrobot420 is offline
#0706 (DON'T KNOW YET!!)
mooveitrobot420 has a little shameless behaviour in the past
Send a message via AIM to mooveitrobot420
Re: One hour Chassis?
Originally posted by oneangrydwarf
Did anyone actualy get their chassis up and running in 1 hour.... i dont mean like just a test bot to run around on the field but the actual chassis for your final robot...
NOT IN A HOUR, but its together...How bout u? U got it up in a hour??
Unread 07-02-2003, 10:08
GavinO GavinO is offline
GavinO is an unknown quantity at this point
The bit that the wheels actually attach to was done in an hour or two . . . but the actual stuff supporting everything is built into other systems so much that the people building those systems were given the additional task of designing the chasis components that would support their system. So . . . the chassis was the last thing to go together, really, and took a lot more than an hour.
Segway in Simcity 4 Rush Hour? KyleGilbert45 Dean Kamen's Inventions 1 07-10-2003 15:46
FIRST's one hour drive Duke 13370 Motors 4 25-02-2003 17:29
Image Discuss: 810 - Chassis CD47-Bot Extra Discussion 11 01-02-2003 18:24
the provided chassis material Andrew Dahl Kit & Additional Hardware 5 09-01-2003 15:26
Sheet Aluminum Chassis: fs_2002 Technical Discussion 4 17-10-2002 10:10
