Go to Post Unless your HS students have earned BSEE and BSME degreees already, how can they lead or run an engineering team? - KenWittlief [more]
  #61   Spotlight this post!
Unread 06-02-2003, 21:15
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Originally posted by Shawn60
I will say it one last time. How can you do anything if your robot is invisible?
It's not like the entire field is blocked. Just add a very large flexible flag to your robot- like a corner flag on a soccer field. Presto!
  #62   Spotlight this post!
Unread 06-02-2003, 21:34
Shawn60 Shawn60 is offline
#0060 (Bionic Bulldogs)
Shawn60 will become famous soon enough
You may need a 7-8 foot flag.
  #63   Spotlight this post!
Unread 06-02-2003, 21:35
Joe3's Avatar
Joe3 Joe3 is offline
Joe3 has a spectacular aura aboutJoe3 has a spectacular aura aboutJoe3 has a spectacular aura about
Send a message via AIM to Joe3
sevisehda [br]OK let me get this straight if I'm on the top of the ramp with 25 "lousy" points. The opponents bots can't low ride and knock all(hard to do because of visabilty) the crates out of the zone. My alliance partner forgot to plug in the battery and is dead. So your human player stacks are undisturbed. You get 4 stack * 4 on the floor = 16. I get 25 plus whatever you miss. My 25 "lousy" points WIN.
Now, this is all on the premise that none of the teams you are playing have the ability to move you. Teams repeatedly running up the ramp bashing into you for 2 minutes WILL move you. And for all of you planning on having wings, you better have a great pit crew and lots of spare parts. Because if you don't give the other alliance anything to do, they will just run into you for the whole 2 minutes. Believe me, it happened to us last year every match.
  #64   Spotlight this post!
Unread 06-02-2003, 21:44
not on CD enough...
There's a solution for everything. Make a joint out of a spring and use a servo to release it.
  #65   Spotlight this post!
Unread 06-02-2003, 23:01
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
hey dudes, you can stay on top of the ramp all day for all I care.
we've decided that it is much more efficient, instead of knocking down the enemy stacks during the autonomous period, to steal the largest stack and deposit it over the bar onto our side of the field. we will then go under the bar and start stacking everything.
give us 15 bins and 30 seconds and we will give you 56 points.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
  #66   Spotlight this post!
Unread 06-02-2003, 23:14
AT man AT man is offline
#0364 (Team Fusion)
AT man is an unknown quantity at this point
Send a message via AIM to AT man
Teams with Wings
Being on the top of the hill will definitely be a key factor. Teams with a large wingspan had better be able to control the spinning factor that they are going to get with 3 130 pound robots smashing into them. Me, I would go for a lower profile with lots of power to be king of the hill.
  #67   Spotlight this post!
Unread 07-02-2003, 04:26
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
Staying on top of the ramp if done correctly can be easy, first of all put your weight at the ends and you prevent most of the twisting. Second who says you have to be on the HDPE during the whole match, you just have to be on it at the end to get points. Why are 3 bots attacking it, if anything while the 2 opposing bots are attcking it the ramp-doms alliance partner are killing the opposing teams score.
Plane and simple. If a good ramp-dom hits the wall and plants then stackers are in big trouble. The ramp-dom can slow down any movement across the field(bots and boxes).
-Solace
Give me a bot that can move and 5 seconds and I'll make your 56 into 15.
  #68   Spotlight this post!
Unread 07-02-2003, 09:03
Alex Forest's Avatar
Alex Forest Alex Forest is offline
MadHatter
#0190 (Gompei and the H.E.R.D.)
Alex Forest is an unknown quantity at this point
Send a message via AIM to Alex Forest
assuming of course that they dont have awesome traction and can defend their stack.. It IS possible you realize to keep a stack frombeing knocked over.
Ahh...the wonderful and new experience of being a college mentor. Wow. its very disturbing to have people thinking that I know what I am doing....*shudder*
  #69   Spotlight this post!
Unread 07-02-2003, 09:26
Joe3's Avatar
I would think planting yourself on the wire mesh would also be very risky. You can't stick anything through it, and if transfer too much energy to that wire mesh, you will bend it, resulting in a possible DQ.
Also...if you have a smaller robot with a lot of traction playing king of the hill, how are you going to stop 2 robots running up at the same time on opposite sides of the ramp?
  #70   Spotlight this post!
Unread 07-02-2003, 10:29
Solace's Avatar
AKA: Jake
actually, we just carry our stack around with us. So yeah, you can know it over, but you'll have to knock us over with it.
...What is a man,
Jake
Team Paragon #571
  #71   Spotlight this post!
Unread 07-02-2003, 10:49
Do you remember how tough the file cards were on the carpet last year? Well, my team found a material that is ever harder to move on the hdpe.
  #72   Spotlight this post!
Unread 07-02-2003, 10:55
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Yeah errrmmm a large push from any robot should give enough force to knock any stack over considering how precarious it will be.
I would like to see the material because hdpe has the traction of ice.
  #73   Spotlight this post!
Unread 07-02-2003, 11:36
Jason Haaga Jason Haaga is offline
no team (Royal Assault)
Jason Haaga is an unknown quantity at this point
There is more than the HDPE. We have a design that anchors the robot and is hard to remove by hand.
I must concur with previous assessments of anchoring to the mesh: bad idea, most likely a DQ waiting to happen. If a ramp dominator could be effective, it'd be a major advantage I agree... It's just going to be a slaughter of anyone who does. 130lbs robot moving around 16fps results in you being dethroned eventually (most likely in multiple pieces). Also while you're up there it is two on one. A decent stacker can put up enough to beat you while his buddy keeps your partner busy.
  #74   Spotlight this post!
Unread 07-02-2003, 11:39
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
We remember we broke the robot that had them. They try to stop us and they lost there arm and cable.
power is still going to be the big deal this year. not how much you can stick to the ground.
  #75   Spotlight this post!
Unread 07-02-2003, 11:43
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
You all seem to believe that your way of doing things is the only way to do things. Your strategies are limited, as they're based on enormously flawed assumptions about the capabilities and strategy of other robots.
There isn't any way a robot can win this game, reliably, by perching itself atop the ramp and sitting there for two minutes. There are just too many variables.
You may have great success in qualifying rounds, of course, since the alliance pairings are at random. But, if you think that you're immune to defeat because you can park your robot on the ramp, I think you'll find that you're wrong. Alliances will construct themselves in such a way as to bring you down. That's a fact of life.
If your robot occupies all 48 ft. sq. of the HDPE surface and does so with strength and immobility, there is no incentive for the opposition to deposit any stacks until the final moments of the game. Where robots that can hold entire stacks at a time are involved, you will not have any success in knocking over their stack. If, by that, the scores become close, or your opponent's overtake you, what other contingencies do you have?
If a ramp blocking robot allows their alliance partner onto the HDPE for an additional 25 pts., beyond taking a great risk of losing all of their points, they relinquish their control of that surface.
There will be robots in this competition that do stuff you didn't even think of, and they'll do it faster and more reliably than you ever thought possible. By parking yourself atop the ramp, you're setting yourself to do nothing more than be a spectator to these amazing machines.
--Madison--
...down at the Ozdust!
King Of The Hill And Others.... Alex Cormier General Forum 18 12-03-2003 09:11
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
how effective do you think robots going under the bar archiver 2001 4 24-06-2002 00:36
Mountain Home & 'The Brawl' archiver 2000 0 23-06-2002 23:20
What about prettiest robots? archiver 2000 8 23-06-2002 23:09
