Go to Post The highest seeded alliance is always placed in the red zone by the computer. In fact, its a great communist conspiracy to mold the mind of teenagers into equating Reds with winners. - Btower [more]
Unread 14-11-2013, 09:53
Matt_4505 Matt_4505 is offline
FRC #4505
Matt_4505 is on a distinguished road
Tank Drive Issues
Hello,
This year I have been switching my team over to Java and we have started to work with a Command Based control system. I built my drivetrain in RobotBuilder and then added code for the Tank Drive. Unfortunately, when I try to run the code, the left Joystick controls both sides of the robot instead of just the left side.
The Code:
DriveTrain subsystem:
public void tankDrive(double leftJoystickValue, double rightJoystickValue){
robotDrive.tankDrive(leftJoystickValue, rightJoystickValue);
public double deadZone (double val) {
return val > 0.25 || val < -0.25? val: 0;
public double adjustSpeed (double val){
return Robot.oi.leftJoystick.getRawButton(1)? val*.75: (Robot.oi.rightJoystick.getRawButton(1)? val*.75: val);
DriveCommand:
protected void execute() {
Robot.drivetrain.tankDrive(Robot.drivetrain.adjust Speed(Robot.drivetrain.deadZone(Robot.oi.getleftJo ystick().getY())),
Robot.drivetrain.adjustSpeed(Robot.drivetrain.dead Zone(Robot.oi.getrightJoystick().getY())));
Thanks
Unread 14-11-2013, 13:15
Re: Tank Drive Issues
I don't see anything in the code that you posted that would output the left joystick to both left and right. Are your joystick declarations correct?
Unread 14-11-2013, 13:18
BigJ BigJ is online now
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
I'm not entirely sure what is intended to be going on in the adjustSpeed method (chained ternary operators are pretty bad for that), but you're using it for each side's input into your tank drive and it seems to be depending on a specific combination of inputs.
EDIT: nevermind I get it now, my only remaining suspicions are the same as Joe's.
Unread 14-11-2013, 13:48
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
To answer your question, I would take a look at the code in the OI class. getrightJoystick() and getleftJoystick() may not be returning what you're expecting.
One suggestion to make your code a little easier to read/use (this isn't goign to solve your problem)...
By changing what the tankDrive method does slightly you can clean up your "DriveCommand" code significantly, without changing how things work.
//DriveTrain subsystem:
        Robot.drivetrain.adjustSpeed(Robot.drivetrain.deadZone(leftJoystickValue)),
        Robot.drivetrain.adjustSpeed(Robot.drivetrain.deadZone(rightJoystickValue)));
//DriveCommand:
        Robot.oi.getleftJoystick().getY(),
        Robot.oi.getrightJoystick().getY());
Maybe it's just my preference, but I prefer logic to be performed by the subsystem. That way if multiple commands call the exposed methods, they always perform in a consistent manner, and it reduces code duplication at the Command level.
http://team2168.org
Unread 14-11-2013, 20:10
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Agreed that you probably have a problem in your OI. And tell us whether you are using 2 joysticks or a video game controller (ie XBox/PS3 controller).
Also, I am glad to see a team using robot builder. Such an amazing yet underused tool, especially for your first year using Java/C++.
