Go to Post BTW - using any Lavery clue to figure anything out could be equally impossible. - Raul [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 15-11-2013, 23:32
Re: Killough Center of Rotation
In case anyone reading this thread is interested, here's an explanation how the omni rotation equations were derived. Scroll to the bottom of the list of attachments.
Unread 20-11-2013, 12:05
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
All,
I have updated the xls to use Ether's algorithm and a cleaner user interface.
Ether,
I think I duplicated your calculations, and I get the same final wheel speed results, but the intermediate alpha angle results for the rear wheels don't look appropriate to me. I have checked the equations several times and I think they match yours. Do they look correct to you?
Unread 20-11-2013, 13:51
Originally Posted by gpetilli View Post
All,
Ether,
Yes, except for the (8,12.25) center of rotation test case. You have a division-by-zero error. You need to put a wrapper around Excel's atan2 function to test the XY input parameters and return a value of zero if both X and Y are zero. That will fix it.
What about them doesn't look appropriate? You do realize they are in radians, right?
They don't match mine. You've got a cosine in there. The equations I posted don't have a cosine anywhere.
Are they correct? They seem to be, for the test cases you have run. Whether or not they are equivalent for all test cases would require further review. If you want to put together a labeled diagram explaining your equations similar to what I posted1 I'd be happy to review it.
1attachment "omni rotation derivation of equations" in this CD-media paper contains figures and a working Octave script showing the equations.
Unread 21-11-2013, 09:05
FRC #1559
Added div0 checks. Hopefully final version.
