Go to Post PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. - dlavery [more]
Unread 17-11-2013, 19:53
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Pancake Cylinder Help
I am in the process of working on a new transmission design in Solidworks as an off-season project. I want to basically use the gears from an AndyMark Super Shifter. However, I want to use pancake air cylinders for the shifter instead of the standard Bimba cylinders that are on their site. I am, however, running into a problem. The AndyMark shifting block that the piston threads into is 1/4-28 female threaded, and the pancake cylinders that I have been able to find are 10-32 female threaded. Has anyone found a good solution to connect the pancake cylinder to the block? I would really love to avoid turning custom screws on out lathe, so any less machine intensive solution would be awesome.
What has your team tried to remedy this problem if you used pancake cylinders? What results have you had?
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 17-11-2013, 20:00
Spen.M.P.'s Avatar
Spen.M.P. Spen.M.P. is offline
FRC #3815 (Raider Robotics)
Spen.M.P. is an unknown quantity at this point
Re: Pancake Cylinder Help
Would something like this work? http://www.mcmaster.com/#92499A136 A standoff with two different sizes.
AdamHeard's Avatar
Lead Mentor
We did this with the next size smaller pancake cylinder, which had an 8-32 Male thread and then used mcmaster 94165A423.
If you insist on keeping that cylinder size you can use mcmaster 90259A129 and retap the andymark block to 5/16-18.
If you also insist on using the female threaded cylinder, you can use a set screw/threaded rod (set screw is better due to the internal hex) to connect them.
Unread 17-11-2013, 20:01
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Lucky for you, West coast products has a solution.
https://store-b98ca.mybigcommerce.com/wcp-00131/
I think 3309 will be switching to these too.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 17-11-2013, 20:08
pmangels17's Avatar
AKA: Paul Mangels
Thanks for the speedy help guys, those are some pretty cool options. I had seen the McMaster standoff thread adapters, but unfortunately they didn't have the right size threads. The other block and the thread within a thread concepts are pretty cool, I'm gonna do more reading too.
Also, Adam, in stepping down a bore size, did you notice a difference in the force that the piston applied? Did it shift less smoothly?
Unread 17-11-2013, 20:10
AdamHeard's Avatar
Lead Mentor
It is less force, but we had no issue with that. We used 9/16" bore for two seasons (2010 and 2011) and they performed without issue.
Unread 17-11-2013, 20:11
pmangels17's Avatar
AKA: Paul Mangels
Awesome, thanks. May I ask where you got your cylinders from? I would imagine the Bimba site but I was just wondering. McMaster only has the female threaded shaft from what I can find.
Unread 17-11-2013, 20:17
AdamHeard's Avatar
Lead Mentor
I believe we ordered those directly from bimba.
Unread 17-11-2013, 20:21
pmangels17's Avatar
AKA: Paul Mangels
Cool, thanks so much for your help. Did you adapt them to an AM transmission or did you use custom transmissions? If you used AM's, what else did you do to adapt them?
Unread 17-11-2013, 20:24
AdamHeard's Avatar
Lead Mentor
When we did that in 2010 we used custom transmissions, but AndyMarks shift block.
You would have to modify or remake the mount plate, and probably change the length of the mounting standoffs.
Unread 17-11-2013, 20:28
pmangels17's Avatar
AKA: Paul Mangels
Okay, I was going to re-do the mount plate anyway so it fit better into the custom gearbox plates. Thanks for all your help!
