Go to Post We learned that no matter the outcome when you don't give up you will always win. - Koko Ed [more]
Unread 19-11-2013, 09:34
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
TCP problems in C#
I've got a small LV TCP server program writing a string to the stream and then on the client side (written in C#), when I read the stream every 20ms, it comes back jumbled after the first read.
For instance, if I wrote a string "a b c" to the stream, it would read like something this for the first four iterations (each line is what is read at 20ms):
"a b c"
" ca b"
"b ca "
"ca b "
Here's the server code, really simple LV server, went off a youtube tutorial
Here's the C# code:
private void timUpdate_Tick(object sender, EventArgs e)
            //update revolutions X and Y and the Gyro Angle every 20ms from the server string value
            //and make sure the connection is solid, otherwise update connection
            Byte[] info = new Byte[Client.ReceiveBufferSize];
            try
                int rData = stream.Read(info, 0, System.Convert.ToInt32(Client.ReceiveBufferSize));
                RobotData = System.Convert.ToString(rData);
            catch (System.IO.IOException)
                lblConnectInd.BackColor = System.Drawing.Color.Red;
                Log("The robot ended the stream.");
                stream.Close();
                Client.Close();
            //split string into X, Y and angle
            strRevX = RobotData.Substring(0, 2);
            strRevY = RobotData.Substring(5, 2);
            strAngle = RobotData.Substring(8, 2);
            //update values recieved in GUI
            lblX.Text = strRevX;
            lblY.Text = strRevY;
            lblAngle.Text = strAngle;
            //convert separated strings into doubles
            Double.TryParse(strRevX, out dblRevolutionsX);
            Double.TryParse(strRevX, out dblRevolutionsY);
            Double.TryParse(strAngle, out dblAngle);
            //make sure we're still connected
            if (Client.Connected == true)
                lblConnectInd.BackColor = System.Drawing.Color.Green;
            else
                timUpdate.Stop();
Does anyone know how to fix this or what I'm doing wrong? I need a quick read time to get accurate data..
Per Audacia Ad Astra
Unread 19-11-2013, 11:05
Re: TCP problems in C#
I'm having a hard time understanding what you want to do. What you're calling the "server" is apparently sending data continuously, and what you're calling the "client" is apparently reading the accumulated data once every 20 milliseconds. Is that the intent?
Normally, I'd expect the client to send a packet of data either on a fixed schedule or whenever the data is available, and the server would wait for data to appear before reading it and processing it immediately.
Unread 19-11-2013, 12:02
The first thing you should do is use a program such as wireshark to capture the TCP/IP packets and determine if they are being sent as discrete packets. TCP is a stream protocol and guarantees that things will be received in the correct order, but they may be packetized differently then you expect. You can learn more by searching for nagle algorithm.
Why are you sending data with no delay in LabVIEW, but reading data every 20ms? You'll probably fill up the TCP/IP buffers fairly quickly.
Unread 19-11-2013, 23:28
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Originally Posted by Invictus3593 View Post
Here's the C# code:
int rData = stream.Read(info, 0, Client.ReceiveBufferSize);
It doesn't match the symptoms you're reporting, but I think you want
RobotData = System.Text.Encoding.Default.GetString(rData);
The code you have is extracting data from rData formatted as a string, where rData is the number of characters read from the socket stream. The actual data read from the stream is stored in info, which you aren't currently using
FRC 766, 2015-, Mentor
Unread 20-11-2013, 09:18
Thank you guys for the replies!
I have to admit, I'm just learning TCP so please excuse any noob-ish mistakes I've made:/
That is the intent, yes. On the LV program, I was following a simple tutorial to write the string; do you have any tips on how I could accomplish what you've described?
I'm not sure I completely understand. Are you saying that, because I'm using LV to write and C# to read, there's a discrepancy in the packet order? And I didn't really pay attention to it, I was following a tutorial . Would it just be a ms timer in the loop?
Oh, dangit. Careless mistake, haha. Fixed!
Do you guys think the problem is on the LV side or the C# side?
Unread 20-11-2013, 09:36
RyanCahoon's Avatar
Did that fix the problem? What's it outputting now? That modification will completely change the results you get
Also, how were you getting "a b c" - the code you had should have only given you numbers since you were just processing the number of bytes read. Were a b c placeholders? It might be helpful if you could give us some concrete examples
Unread 20-11-2013, 09:37
It's on both sides. You need to throttle the sending side so that it doesn't overwhelm the network, and you need to change the receiving side so that it's always ready to receive data without introducing an artificial delay.
Since your application involves a fixed amount of data for each communication, I don't think the stream nature of TCP is helping you any. I suggest that you should be using UDP instead. That lends itself to a very simple structure where your C code can listen for a UDP packet and process the whole thing at once when it arrives.
Unread 20-11-2013, 12:39
I'm saying that the fundamental way that TCP operates makes what you want to do hard, no matter what is doing the sending and what is doing the receiving.
I agree with Alan that UDP is a better choice if all you want to do is blindly read a packet of data.
Unread 20-11-2013, 14:14
I have not had the chance to test it yet, just fix the code, I will post the results after applying this test a little bit later. Originally, it did give me that specific string, but yes, those were placeholders so as to test the program before I actually inputted any real data. The real data will contain "a- encoder x-axis, b- encoder y-axis, and c- gyro angle" and the string that is read is then split up into the three parts and treated as three separate decimals.
How would I go about reading from UDP if not from a stream? Would UDP affect the rate of the data sent? Is the syntax in C# any different? What do I need to keep in mind or be careful of when using UDP?
Sorry for all the questions in a row but I would like to know as much about this as possible so that when try it out, I can troubleshoot.
EDIT: One more thought; would using Network Tables help here? Maybe just getting the string from the LV Dashboard?
If you guys have any extra tips or resources I can check out about the two different protocols, PM me because I'm still learning!
