Go to Post RoboRIO brownout (v, n): The GDC's alternative to limiting the number of motors allowed on a robot. - GeeTwo [more]
Unread 06-02-2003, 17:52
Ryan Collings Ryan Collings is offline
None #0313 (Bionic Zebras)
Ryan Collings is an unknown quantity at this point
Question How do you do the autonomous programming?
Can someone help me with the autonomous programming? I am a rookie programmer.
Unread 06-02-2003, 19:22
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
Could you please be more specific. Programing in autonomous mode is exactly the same as programing normally, except you have to tell the robot to move instead of waiting on sensor input for operator.
If you need any more help post a reply here or PM me or email me @ info@lightningrobotics.com .
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Unread 06-02-2003, 19:34
Jeff_Rice's Avatar
Jeff_Rice Jeff_Rice is offline
ElementisRegamusProelium
#1359
Jeff_Rice will become famous soon enoughJeff_Rice will become famous soon enough
I'm guessing you want to know how to start. Well, granted, I am a rookie, but I have learned a lot.
1.Make a main subroutine and an autonomous subroutine
If auton_mode = 0 then Skip_Autonomous
Gosub AUTONOMOUS ' Jumps to subroutine for autonomous movement '
Goto NEXT_SCAN
Skip_Autonomous:
Gosub Normal_operation ' Jumps to subroutine for normal operation '
NEXT_SCAN:
Or something like that in between Serin and Serout
2. Write pseudocode for how you want the robot to behave
If sensor1 is lit, turn left
If sensor 2 is lit, go straight
if sensor 3 is lit, turn right
3. Be sure not to mess up any of your other code
"He said my name is Private Andrew Malone
If you're reading this then I didn't make it home
But for every dream that's shattered another one comes true
This car was once a dream of mine now it belongs to you
And though you may take her and make her your own
You'll always be riding with Private Malone" David Ball, "Private Malone"
Unread 06-02-2003, 19:40
rust710's Avatar
Or the PBasic 2.5 version
If auton_mode = then
gosub AUTONOMOUS ' Jumps to subroutine for autonomous movement '
else
endif
Basicly the same as 2.0 but looks nicer and is easier to code.
Andrew Radamis
Programmer on 862
Unread 06-02-2003, 20:35
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
else
endif
If you're doing 2.5, you can also do it all in one line:
IF auton_mode=1 THEN GOSUB autonomous ELSE GOSUB normal_operation
I just posted a rather lengthy reply to a similar question in this thread that you may want to look at.
--Rob
Unread 07-02-2003, 12:06
Thank you for the information on the autonomous mode. Now, can anyone help me out with delta_t? How do I get a reading from it so I can time our robot?
Hey Rob, Have you gotten those rpms yet? As always, no rush.
Unread 07-02-2003, 12:39
For delta_t stuff, check out http://www.chiefdelphi.com/forums/sh...threadid=16994.
As for the rpms, I just sent you some stuff. Let me know whether or not it works.
--Rob
Unread 07-02-2003, 13:31
Carl Owenby Carl Owenby is offline
#0654 (Maclay Robotics)
Carl Owenby is an unknown quantity at this point
Example of Autonomous Code
Here is an example of some autonomous code that works. You are welcome to use it as you see fit. Hope this helps.
If comp_mode = 0 then Relay_Control
'Competition Control is disabled
Out7 = 0 'Basic Run LED off when Competition Control disabled
Goto End_Control
Relay_Control:
'Competition Control is enabled
relay3_fwd = rc_sw3 'Air compressor on when pressure switch closed - Green
relay3_rev = 0 'Disable Relay 3 reverse function
relay8_fwd = 1 'Rotating light on when Competition Control not disabled - Green
relay8_rev = 0 'Disable Relay 8 reverse function
If auton_mode = 0 then Oper_Control
'Game is in Autonomous Robot Control Period
Out7 = 1 'Basic Run LED on during Autonomous Robot Control Period
'ADD OTHER AUTONOMOUS CODE HERE
Goto End_Control
Oper_Control:
'Game is in Operator Control Period
Toggle 7 'Basic Run LED flashes during Operator Control Period
relay1_fwd = p1_sw_trig 'Left Index - Lower Left Arm - Green
relay1_rev = p1_sw_top 'Left Thumb - Raise Left Arm - Red
relay2_fwd = p2_sw_trig 'Right Index - Lower Right Arm - Green
relay2_rev = p2_sw_top 'Right Thumb - Raise Right Arm - Red
End_Control:
There are 10 kinds of people in this world; those who understand binary and those who don't.
Unread 07-02-2003, 15:11
BigJohn BigJohn is offline
BigJohn is an unknown quantity at this point
What is the autonomous code, and where do we connect the sensors up at?
Unread 07-02-2003, 15:56
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
Were do the autonomous sensors hook up to the robot.
how do you hook the autonomous mode up to robot.(to work)
All sensors are hooked up through the digital/analog 25 pin ports on the RC.
I'm assuming that by "hook the autonomous mode up to robot.(to work)" you mean how does one simulate autonomous mode. You should go to this schematic to build a dongle for autonomous mode.
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
Unread 07-02-2003, 18:23
Now, can anyone help me with programming SPIKEs for the pneumatics?
Unread 07-02-2003, 19:38
rust710's Avatar
Programming spikes is extremely simple. First find out what port the spike is on and go to your code.
To make a spike go forward relay1_fwd = 1. To make it go backward relay1_rev = 1 . Always remember to set the opposite direction you are using to zero. If you want to stop the relay all together set both variables to zero. Change the number after relay to the port you are using.
Andrew Radamis
Programmer on 862
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous programming Dush Programming 4 20-02-2003 09:54
autonomous sensor programming ? Laura_d Programming 1 10-02-2003 17:46
How far is everyone in their autonomous programming AlphaOmega870 Programming 33 21-01-2003 21:03
