#16
Re: Safer Saws
If these get caught in the drill, saw, etc., then they will pull your face/arms into the drill, saw, etc., and really hurt you. Just remember, keep everything away from the actual tool except the item to be cut, and wear those safety goggles! |
#17
This kind of cool concept just came to me:
Ground the blade of the saw. Have the student grounded. If there is continuity with the student and the blade, shut down the motor immediately. That can be a lifesaver for someone who falls asleep while cutting something. Sorry for the caps, below: THE MOST IMPORTANT: AS MENTIONED BEFORE, MAKE SURE EVERY STUDENT IS TAUGHT SAFETY COMPLETELY. In our school, we are required to take safety tests, which makes me think, maybe that is what I should do, if I become team captain, before I will allow someone to use the tools! |
#18
If you have any hair of a certain length or greater (e.g. 6 inches head, 1 inch mustache/beard, it must be secured and held back or cut off to use certain tools. Nothing's worse than getting a strand of hair stuck within a drill's air intake! |
#19
Re: Safer Saws
Has this been an issue for you?
#20
That was a bit sarcastic, but some extreme cases commonly happen, especially is someone is distracted!
Also, this also just came to me, a vision tracking program watching the user's eyes, making sure they are continuously looking at what they are machining. Seems like a lot of work, but if someone builds one and gets it into production, it can change the lives of workers around the world! |
#21
Re: Safer Saws
Everyone on our team is required to have a 10-hour OSHA certification (school funded, unless you fail) to do basically anything in the lab.
#22
Re: Safer Saws
I didn't know that! However, the SawStop works in a different way!
#24
Re: Safer Saws
You do realize if you ground the blade & the student you are going to have continuity between the 2? Saw will not start using that scheme. Which will keep it safe, but useless.
#25
Re: Safer Saws
^this. Good idea, though!
#26
However, the problem is: if you are machining aluminum, it would automatically trigger, meaning that you would need to measure resistance. I do not see how the SawStop works with metals! |
#27
Re: Safer Saws
They said in the video I posted (see above) it detected the moisture in your hand. I don't know if that was just layman's terms though.
I had a lamp once that turned on by detecting when you touched it (anywhere in it's metal frame). I think it worked because your body acts as a radio antenna, and it could detect the signals to turn on. |
#28
Re: Safer Saws
Just thought of something.
Why would you be cutting METAL with a WOOD blade? However the SawStop works, I guarantee it requires an all metal blade, and will not work with an abrasive ceramic blade, especially since a ceramic blade would probably explode instead of fall through the table (turning a lost finger injury into a horrific shrapnel injury) I've never seen a metal, metal cutting blade for a table saw. |
#29
Re: Safer Saws
This is exactly what happens with a SawStop cutting aluminum. Apparently there's a disable switch for the safety sensing. Ask me how I know...
#30
Re: Safer Saws
I agree. It is a bad idea to cut metal with a wood blade. However, how does the capacitance cause such a change? I think that there is something being hidden from us. Also, with that little voltage difference, wouldn't there be quite a few false alarms?
