Go to Post FIRST is an opportunity for me to tackle problems that have long been solved. - Madison [more]
Unread 18-11-2013, 15:28
Jason Spurlock Jason Spurlock is offline
FRC #0313
Jason Spurlock is an unknown quantity at this point
Power Distribution Board Question
Hi, I'm a mentor from Team 313 - The Bionic Zebras, and now I'm participating in a college robotics club and we want to use the FIRST power distribution board, but the robot we want to build has motors that run off of 24 volts. What would happen if we put 24 volts through the power distribution board? The spec sheet for the power distribution board says that it can take 6-15 Volts. We do not know why there is a operating voltage range because we are assuming all the grounds are internally connected and all the positive power is internally connected so voltage should not matter, right?
Unread 18-11-2013, 15:32
Re: Power Distribution Board Question
EricVanWyk designed the PDB I believe. You might try sending him a Private Message.
Unread 18-11-2013, 15:41
Domtech's Avatar
Domtech Domtech is offline
I Do Everything
AKA: Dominic
FRC #2412 (Robototes)
Domtech is an unknown quantity at this point
The Limited voltage range is most likely due to the limits of the internal power regulators (the 5V 12V and 24V outputs at the front with lights next to them).
You might be able to disassemble the board and cut the power going to the regulators if you need it to purely distribute power.
Unread 18-11-2013, 15:46
There are a number of active components in the PDB including the regulated power supplies and the break pop LEDs. You could review the schematic and evaluate each one. I don't think anything would stop it from working as a dumb PDB, you might not want to return a PDB with damaged components to the team.
Unread 18-11-2013, 15:47
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You'd probably be better off with something like this
http://www.arlingtonproducts.com/ser...osition/Detail
which is similar to what was used on FIRST robots before 2009
Unread 18-11-2013, 16:50
There is a lot of internals designed to run from the !2 volt bus, breaker sense, Crio, camera and radio power supplies, LED tallies, etc. The voltage spec has nothing to do with input to output wiring.
Unread 19-11-2013, 07:32
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
What would happen if you put 1200v through it? or 12000v? I'm not an electrical engineer but my gut tells me there are also limitations to the traces and internal wiring itself.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 20-11-2013, 22:33
yash101 yash101 is offline
AKA: null
Lightbulb Re: Power Distribution Board Question
I do not get this thing about amps and volts. Most people think that it is amps that kill. Why is it that if you have 12,000 volts and 1 microamp, you can still die a painful death? Isn't it wattage that kills?
So, you may be wondering how this goes with this topic:
Well, the traces would probably break down if you had a high voltage and low amperage because the wattage will still be high. Wattage is Voltage times Amperage. A supercapacitor of 1 volt will do the same damage as a 12 volt battery outputting a tenth of that amperage.
Using Ohm's law below:
If the trace has a resistance of 1 ohm, 10,000 volts at .0001 Amps would equal to ten watts.
With the same resistance, 1 volt at 10 amps would equal ten watts.
That is the same amount of energy. No less, No more! The only difference is that in the first scenario, there is a high pressure and low flow. In the second scenario, there is a lower pressure but a higher flow. It is more-or-less the same as converting potential energy to kinetic energy and back!
Ohm's Law:
I = E / R
E = I * R
R = V / I
General Power Law:
P = I * E
E = P / I
I = P / E
P: Power
E: Voltage
I: Amperage
R: Resistance
Guys, Please let me know if I am misunderstanding physics here!
Unread 20-11-2013, 22:55
MrForbes's Avatar
AKA: Jim
In electronic circuits, the size of the conductor must be large enough to handle the current. And the insulation (or trace spacing) must be good enough to handle the voltage without arcing.
We look at current and voltage specs separately in most cases.
But power....watts...that is important because of the heat that must be dissipated.
It's not a matter of understanding the physics of Ohm's Law. It's a matter of understanding the engineering requirements for the different properties of electricity.
Unread 20-11-2013, 22:56
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
12000 Volts and 1 micro amp will not hurt you. When you get shocked when you touch a door knob, for example, that shock can be well over 100,000 Volts. Amps is what does the damage. You are correct in Ohm's law and the Power law, but the amperage that you list is not high enough to cause pain. See this Wikipedia article. http://en.wikipedia.org/wiki/Electric_shock
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 20-11-2013, 23:03
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
There are much, much better options out there then the current FRC Power Distribution Board.
As MrForbes stated, something like the pre-2009 control system pd components would work fine - and probably be cheaper. I can't imagine you needed anything too fancy.
Unread 21-11-2013, 07:36
Where to start?
Lets do the volts vs amps question. GFI breakers are designed to trip off at less than 4-6 ma since above that level is the current that seems to interrupt the heart function with regularity. However, at much less than 120 volts (the RMS value) the skin and body resistance will limit that current. That is why you can touch the terminals on the 12 volt battery and not be harmed. 48 volts on the phone line can give you a really uncomfortable tingle. This is all assuming you do not already have some electrical issue with heart function or have a pace maker. As you increase voltage the induced current will change. If the current is limited in some fashion, the high voltage still can cause other effects like local skin burns and muscle damage.
As Jim has pointed out above, high voltage requires precautions with insulation and exposed conductor spacing. The transmitter I work on has a 35,000 volt, 2 amp power supply. The wiring has a multi-layered insulation that requires regular replacement to prevent it breaking down. All the parts that are at this elevated voltage also have an anti-coronal design so that the voltage has a uniform field around the parts. This prevents discharge and the accompanying arc burns and localized welding of parts. There are no sharp edges on anything in the high voltage cabinet. Yes, at 2 amps, the wiring really needs to be only #22 wire. However it is larger than that simply to support the insulation and other factors. The overall diameter is about 1/4".
On to the power rating, yes the 35kV@2 amps gives you 70kW which is the amount of work that can be performed and this transmitter is generally capable of making 30kW at full power due to inefficiencies and head room. Here is where things get a lot more complicated. The RF at that level behaves much differently than DC of the same peak voltage. Even at low currents, severe muscle damage can occur with severe burning. The currents tend to flow at the surface of conductors and depending on frequency can penetrate the body to varying depths.
As to the PD, the conductor spacing, board composition and other factors would easily handle at least 50 volts and likely 100 volts DC. (The electronics as I mentioned above are designed for 12 volts and will be destroyed at 24 volts and above.) However, whether the PD would pass electrical laws (i.e. NEC) for those levels is unknown. I think that the WAGO is speced up to 300 volts. However, the current PD in my opinion, is far superior to the power distro used in earlier years. At least you do not need multiple tools to terminate wires and it is much easier to mount and use.
Unread 21-11-2013, 11:55
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Don't you just love it when Al breaks it down for us non electrical guys!
Andy Brockway
Team 716, The Who'sCTEKS
Unread 22-11-2013, 12:29
The FETs controlling the blown breakers would become marginal. They are rated at 25V, so you are right up against their rating. It would become possible for a voltage spike to push you well past their rating and blow them.
The PTC fuse for the regulated 12V supply would be well out of spec and no longer provide protection.
The 12V power supply indicator LED may burn out.
Most of the input capacitors for the power supplies would be over-volted. This would likely cause part failure (which would become self-clearing, loudly and with odor). It would definitely cause severely increased noise on the output.
The 12V regulated power supply would not be in regulation.
Depending on what year PD you are using, the 5V supply might pop.
The quick summary is that the PD design could easily be tweaked for a 24V input, with most rework for the 12V supply, but it wasn't.
