Re: Carbide Lathe Tooling Advice
Another supporter of latheinserts.com /ccmt/ccgt inserts here.
For general OD/ID turning/boring my personal favorites are 32.52 CCMT's with the LF chipbreaker (http://www.maritool.com/Indexable-To...uct_info.html). I prefer the 32.52's over the 32.51's for the larger radius, (.032 v .016), this makes the radius a little stronger and gives better finish, as long as you can stand the .032 radius on your parts, or the time it takes to remove it (not much). The CC_T geometry is relatively common, and has positive rake, which is desirable for aluminum and lower horsepower machines. You can find these inserts all over the place, you can even find great deals on name brand 10pks on ebay. Used properly, CC_T inserts will last a very long time in aluminum, I think I got at least 500-700 gears out of each edge on mine. With whatever insert types you choose, I strongly recommend you standardize inserts across all your tooling. Having one insert type for your turning/boring tools really helps keep you productive, since you can swap inserts across tools if you run out or break inserts. The SCLC series, for holding CC_T series inserts are my favorite. For cutoff tools, the self-locking GTN series inserts and holders are my favorite. These make a shocking difference over standard HSS parting blades. Here's links to SCLC Boring Bars: http://www.shars.com/product_categor...r_CCMT_Inserts SCLC Turning Holders: http://www.shars.com/product_categor...r_CCMT_Inserts and a handy insert lookup chart to decode insert designations. http://www.carbidedepot.com/formulas-insert-d.htm |
Thanks for the replies! I'll take a look at some of those sets.
Our bigger lathes have some power. They are a variation of the imported 1340G model available in several colors and logos. With HSS tooling last year we were pulling some heavy chip coils off aluminum before they started bogging down. Couldn't quite get a good chip breaker ground into the tool bits with the shop grinder. The lathes are fairly tight, if made to be. The setup for any precision job involves some form of minor rebuild that will last a week or two before it is back to slop Judging from the work left around the shop by the usual users, you'd think they were using a tire iron as cutter... The abuse just shakes the screws and gibs loose. We have no holders yet, which is why I wanted to pick a type that was good for most robotics work and standardize on that, as AlecS mentioned. |
I bought a pack of these back in 2006 and it's all I use for turning and facing on two different lathes. I haven't even been through half of them yet.
I'll pile on to the rest - just pick up SCLCR/L (RH & LH) holders in whatever size you like, and a pack of aluminum/nonferrous inserts. McMaster sells Dorin holders at ~$48 each, and the aluminum specific inserts are $6.90/ea for a box of 10 (3244A316 or 3244A318). I forget the brand of the inserts, might be Mitsubishi.
Shars also sells the "CCMT" style aluminum specific inserts, they're listed as CCGX on their site. Never tried them, but in case you wanted to pick up the boring bar/holder cheaper from them. http://www.shars.com/products/view/8..._3251_LH_YD101 |
As a side note,
We've been going through our tooling and consolidating it all. One thing that we liked doing was making sure most if not all of our lathe indexable tooling used the same insert. We currently have two lathes and are picking up a third soon. So its nice that the inserts work across both machines. Our boring bars, turning holders (1/2" thick and 3/4") thick both use CCMT. We went with the 32.5X size. Inserts from latheinserts.com or Maritool are awesome. For all our grooving stuff we use thinbit, the inserts work both in the 1/2" and 3/4" holders we own. Quote:
-RC |
Before you spend a lot on tooling, contact a local dealer and see if they have a holder and inserts to try. You may find that your machines can not handle the heavey cuts that carbide likes. |
#7
A few years ago we had a retired machinist mentor our team and he put me on to TCGT inserts:
http://www.kbctools.com/can/Navigati...fm?PDFPage=251 They work very well for aluminum and plastic. For steel we use a more robust insert like TNMG: http://www.kbctools.com/can/Navigati...fm?PDFPage=260 The triangular inserts work well for general purpose turning and facing. We already had the toolholders, so we stuck with that geometry. For retaining ring grooves we use the Nikcole mini system: http://www.kbctools.com/can/Navigati...fm?PDFPage=330 Another thing to consider is a quick change tool post: http://www.kbctools.com/can/Navigati...fm?PDFPage=486 We installed one of these a couple years ago, and it has dramatically improved the efficiency of our lathe. |
#8
Any 13x40 lathe will handle a CCGT/CCMT or similar high positive insert with no trouble. Our mobile trailer has a POS JET 9x19 lathe and the only thing we run on it is inserted carbide tooling (WNMG) and it runs fine. |
