Go to Post In the encyclopedia of FIRST under the term Encyclopedia it says - See Joe Ross. - rees2001 [more]
Unread 21-11-2013, 20:23
aryker's Avatar
aryker aryker is offline
FRC #0868 (TechHOUNDS)
aryker will become famous soon enougharyker will become famous soon enough
Re: ping and tracert networking question
This happens on my home network as well. The situation isn't exactly the same, since I don't have a WISP. Instead, I have sort of a LAN within a LAN that I use for testing purposes(I work as a researcher for a distributed systems and security lab). For me, the problem is old wifi hardware that is probably nearing the end of its lifespan, which I am also too lazy to fix until it dies completely
Can you give more information on what hardware you are using? That could be the problem. Also, do you know anyone else who uses the same WISP who may be having similar issues? If that is the case, it's probably an issue on your provider's end, in which case you should contact them and see if they can isolate the issue.
Unread 21-11-2013, 20:39
Ubquiti AirOS PowerStation2
Unread 21-11-2013, 21:33
aryker's Avatar
Hmm--unless you bought it used, I doubt that's where the problem is. When it is not working properly, are you still able to navigate to a web page(i.e. make HTTP requests) successfully?
Unread 21-11-2013, 21:42
No. For purposes of this discussion, not being able to access web pages is what I mean by "not working properly".
Unread 21-11-2013, 21:45
aryker's Avatar
Just checking
How frequently does this occur? Multiple times per day? Per week? Also, I assume you've taken a look at your PowerStation during these times to make sure nothing was obviously out of place?
Unread 21-11-2013, 21:56
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
How many hops in your traceroute when it is working?
Are you going to a DNS entry or an IP?
Unread 21-11-2013, 22:02
Even a tracert to an IP 3 hops away doesn't work (or takes forever).
Unread 21-11-2013, 22:08
techhelpbb's Avatar
Trying to figure out if you are pinging your local gateway which will work even without the tower but tracerouting to a website which times out over ICMP because the tower is not connected (you can traceroute over UDP as well). That is why I asked how many hops when you are working I assumed you tracerouted to a fixed place in the network before the Internet.
Unread 21-11-2013, 22:15
I thought I answered that:
Maybe I'm not understanding what you're asking.
Unread 21-11-2013, 23:38
techhelpbb's Avatar
The IP 3 hops away is probably at the network level near that ISP's perimeter.
So if the DNS doesn't turn out to be the issue you probably have lost your connection to them over that link.
If you have the information to access the equipment on your side you can probably query the status of the connectivity to the tower from the web interface. I think that unit supports SNMP as well so you could query the status of the link from that. They appear to have an MIB for that purpose available. Then you could work it out such that you can monitor the signal level and data transmission rates.
Unread 22-11-2013, 05:37
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Just out of curiosity, what addresses are you pinging and what addresses are you tracerting too?
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 23-11-2013, 16:08
nuttle nuttle is offline
AKA: Allen Nuttle
FRC #4080
nuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud of
This question leads to an iceberg answer, in that there's a lot to say. Here's the tip, so to speak:
> I can ping the tower but tracert does not work (or takes an inordinately long time).
The short answer is that you are most likely not pinging the tower, but something more local. The DNS servers are not likely to be local either, so DNS name resolution isn't likely to work either when you are having connectivity issues.
The analogy here is that to reach an endpoint (specified by IP address, possibly after the additional step of DNS name resolution from a textual name to an IP address that is an independent network operation that itself requires a healthy network connection), you have to traverse a network of roads. You can think of each intersection on this network of roads as having its own IP address. To get almost anywhere, the first few intersections are going to be the same, they take you from your home, out of your neighborhood, and onto a major road. Once you're on this road, chances are you are going to get where you are going, unless there is a problem toward the other end of the journey, when you are getting back onto local roads in the destination neighborhood. Or, if there's no one home at the address on the other end (the site or server is out but you can get to everything else).
There is a span of road that is sometimes out in your case, most likely the over-the-air link. If this happens, you can reach intersections or even end addresses that are local and do not require traversing the span where there's an outage, but can't get further.
Take a tracert when things are working, and let the IP addresses be resolved back into textual names (don't turn of DNS resolution when tracert for a working connection). These names may give you clues. Keep the list of names and IP addresses to some well-known site handy for comparison when things are out.
You will likely find that when you run a tracert that stops at some point, you can ping the addresses that it could reach, you just can't ping ones that are further away on the network. The first place you can reach when things are working but cannot when they are out is the far end of the link that is giving you problems. If you want, you can post details here and we can comment further.
Hope this helps!
Unread 21-11-2013, 22:11
Jared Russell's Avatar
Taking a year (mostly) off
It could be DNS resolution. Most implementations of tracert will attempt to resolve each IP along the way, and this can take a long time with a flaky DNS server.
A couple suggestions:
a) Try running tracert with the -d flag (Windows) or -n (Linux).
b) Try using an open DNS service, like OpenDNS (208.67.222.222/208.67.222.220) or Google Public DNS (8.8.8.8/8.8.4.4).
Last edited by Jared Russell : 21-11-2013 at 22:25. Reason: Clarified that -d is only for Windows
Unread 21-11-2013, 22:18
Originally Posted by Jared341 View Post
It could be DNS resolution. Most implementations of tracert will attempt to resolve each IP along the way...
OK, this is where I have some confusion. I thought DNS was to resolve a name into an IP address. Why is DNS required if I am already providing the IP address?
a) Try running tracert with the -d flag.
Thanks. I will try that next time it misbehaves.
Unread 21-11-2013, 22:23
OK, this is where I have some confusion. I thought DNS was to resolve a name into an IP address. Why is DNS required if I am already providing the IP address?]
By default, tracert will still use DNS to try to look up a name for each hop so it can display it as part of the output. Use "-d" (Windows) or "-n" (Linux) to tell it to skip that part.
