Go to Post try to be careful and follow good safe practices. - meaubry [more]
Unread 21-11-2013, 17:24
multi booting
I've been having a blast playing around with my "guinea pig" PC installing various OSes and setting up multiboot.
So far it will boot FreeDOS, DOS62, Win95_OSR2, Win98SE, WinXP_Pro_SP3, and Linux.
Why?
1) To learn the technology
2) So I can boot any of my machines to DOS for development of timing-critical apps and/or apps that need exclusive and unimpeded direct access to the bare metal.
3) To run legacy DOS apps that don't like emulators.
For you multi-booters out there, what boot manager do you use?
Unread 21-11-2013, 17:35
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: multi booting
I've always liked LILO.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 21-11-2013, 17:38
Re: multi booting
Why?
Unread 21-11-2013, 18:28
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Are you using GRUB right now? Does it do what you need?
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 21-11-2013, 19:18
Re: multi booting
Yes.
Boots logical partitions
Boots disk images
Leaves the partitions unmodified
MBR installed only once
Does not require its own partition
Edit a simple text file to add new boot partitions to the menu
Can manually enter boot commands at boot time if need be
Unread 21-11-2013, 19:48
yash101 yash101 is offline
AKA: null
Talking Re: multi booting
I use WIndows Boot Manager! Yes, I am not the best with advanced things. I currently have two Windows 7 Installations and an Ubuntu installation. I use WUBI for Ubuntu because it is easy to install and uninstall ubuntu with that boot loader!
Unread 21-11-2013, 20:25
aryker's Avatar
aryker aryker is offline
FRC #0868 (TechHOUNDS)
aryker will become famous soon enougharyker will become famous soon enough
Re: multi booting
I am a big fan of GRUB and GRUB 2. Personally I find that the original GRUB is a bit easier to work with, but that's probably because I grew up with it.
Unread 21-11-2013, 20:35
Re: multi booting
Originally Posted by aryker View Post
I find that the original GRUB is a bit easier to work with...
Could you give some examples?
Unread 21-11-2013, 21:25
aryker's Avatar
Re: multi booting
Sure--the main thing that comes to my mind is adding new operating system entries to the GRUB boot menu. In the original GRUB, all you needed to do was add an appropriate entry to the /boot/grub/menu.lst file. Maybe something like this:
title Fedora
root (hd0,1)
chainloader +1
Whereas in GRUB 2, you cannot edit the corresponding menu file(which I believe is /boot/grub/grub.cfg) by hand like that. Instead, there are two different places you have to look into: /etc/grub.d/ and /etc/default/grub.
/etc/grub.d contains a set of scripts that represent separate entries in the menu(among other things) which you should edit/add to if you want to add more entries.
/etc/default/grub is a customization script for the GRUB 2 menu, which you can use to change preferences, except when it comes to the actual menu entries themselves.
This is the main reason why I prefer the original GRUB--which one looks more convoluted to you?
Unread 21-11-2013, 21:30
Re: multi booting
Me too.
Unread 21-11-2013, 22:41
AKA: null
Re: multi booting
I prefer GRUB2 Too! However, my family likes Windows Boot Mgr, because they aren't so tech savvy . I loved Grub 2 when I had it . It, indeed, is quite customizable, and does everything it claims quite well ! As many people have said before, it is very easy to operate on and get things running smoothly. Corrupting your BSD in Win. Boot Mgr. is hard to fix because you need to reinstall Windows . However, GRUB 2 just requires you to edit a text file or so to configure it, meaning you can bring your computer back to life. I also like how it has so many features and how it actually has color, as compared to the Windows Boot Manager.
In short, there are many boot-loaders out there, today, being developed. I use the Windows Boot Manager because I am basically locked into using it. However, I would suggest Grub 2 because, if I understand correctly, you want to multiboot many operating systems.
If you manage to break the bootloader configuration, it is many times easier to fix it in Grub, as compared to Windows. However, I am talking about Win 7. Win 8 Boot manager is completely different!
You need to add many operating systems. That means that you would want to be able to add and remove operating systems with ease, not worrying abouy damaging your MBR!
In short, Go GRUB2!!!
Also, has anyone tried a different boot manager like Burg (Grub Backwards? )? How was it? Was it easy to use/worth getting?
Guys, this is just my opinion on what I have used before.
Unread 22-11-2013, 11:47
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: multi booting
http://www.plop.at/en/bootmanagers.html
I use that when I need features that a BIOS lacks like booting from USB.
Unread 23-11-2013, 00:44
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Lightbulb Re: multi booting
I only have one multi-boot machine. I use vitalization, so I have simultaneous access to all OSs, other than access to physical hardware, it works excellent.
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 24-11-2013, 01:08
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: multi booting
I prefer GRUB2 for two reasons - better auto-config (update-grub) and more features (backgrounds, resolution, timing, more support for OSes).
All opinions are my own.
Unread 29-11-2013, 17:48
AKA: null
Re: multi booting
What software do you use for virtualization? I would like to use virtualization instead, but don't know where to start!
