Go to Post The Championship is not always about bringing the robot...it's about learning, experiencing, and celebrating FIRST. - Jessica Boucher [more]
Unread 22-11-2013, 10:27
Re: Two Power Distribution boards?
Tessa,
Eric has perhaps covered all the bases on this one. To satisfy the rules, one and only one PD. However, as things change from year to year, the best method will be to address this through the Q&A when it opens after kickoff.
As a rule of thumb, when a team starts to load up the robot with motors, current does increase. Several teams tripped main breakers during last season for this reason. While the 120 amp breaker can withstand 600% over current for short periods, it is not self resetting. Once it trips you are done for the match.
Unread 22-11-2013, 10:57
Isaac501 Isaac501 is offline
FRC #0501 (The PowerKnights)
Rookie Year: 1995
Isaac501 is just really niceIsaac501 is just really niceIsaac501 is just really niceIsaac501 is just really nice
Why (and how) would you make a decision to use so many motors without even knowing what the challenge is?
You've put the cart before the horse.
Team 501 Academic Advisor, Systems Build Mentor
Unread 22-11-2013, 11:27
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Originally Posted by yash101 View Post
Yes. I agree. That is why you group the motors that you know will rarely work together.
This is incredibly dangerous. From melting wires to blowing breakers/fuses, this is really not safe and I could see it failing inspection.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 22-11-2013, 18:52
yash101 yash101 is offline
AKA: null
Yes. I know that it is dangerous. That is the reason why you do not group two shooter motors together or drivetrain motors together! Just choose motors that will always run independently. Also, yes. I am pretty sure as soon as the inspection finds out about this the team would get blasted. That's why you do not use this at competition. Also, this adds a little bit of competition. This adds a quota and another thing to watch out about!
More competition also means more competition, usually!
