Go to Post There hasn't been an announcement to buy pool noodles yet. Considering that they are already out of stores in most of the country, draw whatever conclusion that you like. - Joe Ross [more]
Unread 08-02-2003, 00:39
Robb Gerber's Avatar
Robb Gerber Robb Gerber is offline
#1620 (CSIS)
Robb Gerber is an unknown quantity at this point
We've discovered that not all couplers are made alike.
With two drill motors installed we noticed that one had a slight
wobble. After some close inspection we noticed that the coupler that screws onto the drill shaft was defective.
The peice was not drilled in the center. This caused the
deflection on the end of the transmission shaft.
We called a team down the road and got their two couplers
(Thanks Team 188 - Blizzard!). Back at home base we
screwed these in and while they're better, they're still not perfect.
So now we've got 3 and all of them a different. I put in the best one and spun up the motor. Its a lot better than before. In fact,
it'll have to do because I'm stuck with these cruddy couplers.
(I wish I used lovejoy couplers)
One one else experience this?
Unread 08-02-2003, 01:51
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
Ours wobble too. I think that FIRST drilled them wrong.
Unread 08-02-2003, 01:54
Alvin Alvin is offline
Alvin is an unknown quantity at this point
Same here. I should hope that that does not create a significant problem or anything.
I wonder what happened to our 2nd left-handed screw; it seems as though it never came in the kit. Had to get a replacement from MMH.
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
Securing hex shaft to drill output D. Gregory Technical Discussion 6 24-01-2003 14:05
