Re: [FTC]: Tethered/Bluetooth Control
If you are using labview, you can probably tether using a cord or through bluetooth and then you can use the run program function which is in the remote control.
I'm sorry if I wasn't clear- We want to be able to run teleop through a cable or bluetooth.
On Labview, in your robot project center, open the 'default configuration.rcc' file under Remote Control.
Once you get to that window, on the left sidebar, click "Run Program", then change the setting from Prototype to FTC Game, select your Teleop VI on that selector menu, and start the test and enable the bot. Hope this helps. |
That's just what I was looking for. Thanks.
