Go to Post "For once, the cake is NOT a lie." The cake claims liar's paradox. :p - JesseK [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 23-11-2013, 01:33
efoote868 efoote868 is online now
foote stepped in
AKA: E. Foote
FRC #0868
Re: Mecanum Differential Drive
Originally Posted by Oblarg View Post
Acceleration in FRC (with the exception of 2009's wonky drive surface/wheels) has never been traction-limited, so this is purely a function of the gear ratio people are using on their drives. There's nothing about a shifter which would provide any significant benefit to a mecanum bot; a well-designed mecanum drive is geared for high-speed at all times, because the ability to push is something you've already compromised on.
A well designed two speed gearbox has a significant advantage in acceleration. DC Motor power is on a curve, and the well designed gearbox will keep the motor close to peak power. Without a shifting gearbox, 16 fps in FRC provides nearly no advantage to 12 fps or 8 fps.
Your setup adds two gearboxes and two motors to the assembly, but I don't see how you get a significant benefit in return. When moving forward, you'd still have two CIMS pushing each side (as the auxiliary motors won't be doing anything, if I understand correctly), so you don't have any more effective, power-wise, than the standard setup.
No, the auxiliary motors would be used in this setup as well. In the picture presented, 8 motors would be driving this robot when it is going full forward. Alternatively, 1 motor could be in gearbox A, which would allow for 6 motors driving full forward in mecanum drive.
The alternative configuration is that planetary gearbox C does not have an auxiliary motor, which would mean that only 4 motors are driving forward.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
