Go to Post Holy cow! Five years in FIRST and it only gets better! Skyway has supplied wheels to FIRST for ten years. Ten years ago Dean called Ken for wheels. Ken said yes. Man, we love helping you guys and gals get good wheels. ;) Bart at Skywaywheels.com - SkywayWheels [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 23-11-2013, 14:11
FRC #1836 (MilkenKnights)
Re: Mecanum Differential Drive
Originally Posted by efoote868 View Post
In FRC, 16fps for a single speed has no advantages to 12fps for a single speed. By the time you accelerate to the top speed, you're already clear across the field.
You can't use 6 cims in present mecanum drives.
Your calculations are totally dependent on weight. Acceleration on a 90lb robot is fine. Just look at 254 to see very sucessful drivetrains that have been geared fast(16-18 fps).
While you can't run a 6 CIM mecanum, you are ignoring the fact that at this weight and complexity you might as well make an octocanum or swerve.
Controlling a robot through 4 independent shifts on a mecanum drive would be difficult.
Teams do it all the time on butterfly. Mecanum is no different.
8 years ago if I told you that in the future, mecanum wheels would be available for purchase to every team at a reasonable cost, you would have called me crazy.
Honestly I have no idea what will be available in 8 years, so it isn't worth speculating about.
Unread 23-11-2013, 14:23
foote stepped in
AKA: E. Foote
FRC #0868
I'm not ignoring that, I even stated it as a problem in the OP.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 23-11-2013, 14:44
Oblarg Oblarg is offline
AKA: Eli Barnett
Actually, thinking along these lines, has any team tried a 4-shifter mecanum with locking rollers? Seems to me it might be a nice alternative to octanum; it'd offer pretty much identical functionality with comparable complexity/weight.
"The breakfast of champions!"
Unread 23-11-2013, 16:26
Complexity and weight isn't comparable whatsoever. Look at 3928 butterfly and 973's offseason butterfly. Substitute in mecanums and you have a octocanum. Their drives are significantly less resources than a WCD even and almost as light.
Unread 23-11-2013, 17:06
AKA: Eli Barnett
Shifters aren't that much heavier than normal toughbox nanos (~3-4lbs extra, total), and a locking mecanum system doesn't add much weight either if you build it intelligently.
In terms of moving parts, you've got four extra cylinders on a locking mecanum system, yes, but you remove the need for an extra belt, axle, and pulleys.
With the probable advent of 4'' mecanums from VexPro (which one could run straight from a CIM with direct-mounted gears and no gearbox), octanum does get quite a bit lighter, admittedly.
Unread 23-11-2013, 17:07
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
What about a swerve drive with mecanum wheels? haha nevermind...
Unread 23-11-2013, 17:12
AKA: Eli Barnett
Nah, that's not good enough, you've gotta put octanum modules on the swerve modules.
With locking plates on the mecanums, of course.
Unread 23-11-2013, 17:36
I am Dave! Yognaut
AKA: Brian Bray
Unread 23-11-2013, 19:35
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Care to expand?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 23-11-2013, 19:52
They both use the same basic design:
https://scontent-b-lax.xx.fbcdn.net/...29116488_n.jpg
https://scontent-a-lax.xx.fbcdn.net/...54889069_n.jpg
Essentially they have gotten butterfly down to the bare minimum causing it to be extremely easy to make(easier than a WCD) and just a bit heavier.
Unread 23-11-2013, 20:02
AKA: Eli Barnett
With current COTS hardware, it's very hard to just swap out those omni-wheels with mecanum wheels without any changes; the 12t pinion on the 72t gear direct-mounted to the wheel relies on a 4'' wheel to work.
Incidentally, 4464 is making a slightly-modified version (we've made some material/layout changes to accommodate our specific machining capabilities) of that second type of module (actually, we cribbed most of our design choices from RoboWranglers - they had one of their modules on display at Worlds this year) as an offseason project.
Unread 23-11-2013, 20:06
AdamHeard's Avatar
Lead Mentor
Our variant of this was trivially different (biggest difference was using 2" tall tube versus 3") and I can confirm it was easier to manufacture than our WCDs. There just aren't a lot of parts.
Unread 23-11-2013, 20:28
The omni wheel is 6" dia and the traction 4" dia. I don't see the problem
Unread 23-11-2013, 20:31
AKA: Eli Barnett
I am quite sure that omni wheel is 4'', with a 72-tooth VexPro gear on it; vexpro does not sell gears that are that size proportional to a 6'' omni.
Unread 23-11-2013, 20:46
VexPro doesn't sell a traction wheel smaller than 4" either
