Go to Post And trust me, the very last thing you want to see is me with time on my hands and access to power tools. - dlavery [more]
Unread 06-02-2003, 17:50
Pat C. Pat C. is offline
AKA: WebGodd
#0868 (TechHounds)
Team Role: Webmaster
Pat C. is an unknown quantity at this point
Fuse Box Mounting
I am on the electronics team at Carmel High school, and we have an itching question. Are we allowed to directly mount the fuse box to aluminum or does the aluminum have to be insulated? A quick reply would be appreciated so tha we don't have to completely change all the wiring of our bot. Thanks.
Pat.
ALL YOUR BASE ARE BELONG TO US!
Unread 06-02-2003, 19:35
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
I think as long and no current gets to the aluminum you can mount it directly. That is what our team did.
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Unread 06-02-2003, 19:46
Jferrante Jferrante is offline
Jferrante is an unknown quantity at this point
Send a message via AIM to Jferrante Send a message via Yahoo to Jferrante
you can legally mount it directly to the metal, however your better off putting a thin piece of wood or lexan inbetween, just incase a wire comes loose.
GodBless America
September 11, 2001... NEVER FORGET!
All Gave Some. Some Gave All. How much are you willing to give?
FDNYPD
Unread 06-02-2003, 21:07
illumanat'i's Avatar
illumanat'i illumanat'i is offline
make me care
#0555
Team Role: Student
illumanat'i is an unknown quantity at this point
Send a message via AIM to illumanat'i
you can basically do whatever you want with wiring and electronincs, the only thing i've seen specified as needing insulation is the light... there is a rule that the robot frame can't be grounded, so better safe then sorry i'd say
Trust, Love, and Magic
Unread 07-02-2003, 16:19
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
just get out a handy dandy continuity tester and check to make sure its not grounding to the robot chasis and you should be alright if its not.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 08-02-2003, 09:56
Pat,
This requires a little more than a simple explanation. If you are talking about the 12 way breaker panel, there are mounting holes built in that are protected (insulated) from the block and no special material is needed. (I think #8 hardware works here or ty-wraps)
If you are talking about the new 40 amp block, it also can be mounted right on the frame but you must be careful. There is a tab sticking out the back that was designed to fit into a slot you can use that for one attachment point. Then on the opposite end of the block there is a protected (shoulder) hole for a mounting bolt. Do not use the attachment point for the electrical tie in for mounting purposes. I am recommending that teams be very careful when using this new block, (use an insulator under the electrical bolt to insure it does not contact the frame) and to mount it in a protected area where another robot won't accidentally contact the block during comp.
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
box grabbing matt111 3D Animation and Competition 3 27-01-2003 23:08
project box archiver 2000 2 23-06-2002 23:01
Gray box limitations Tim Skloss Technical Discussion 1 23-01-2002 07:38
Modular Control box assembly Andrew Wyatt Technical Discussion 4 29-11-2001 15:44
