#16
Hmmm
You know tank treads arent a bad Idea because you will have a O degree turning radius. but I really wouldnt only use 2 Cim's I would use 2 Cim's and 2 drills at the same speed. Err I dunno if that would work, but I was always a huge fan of 2 wheel rear drive with 2 Cim's with 2 Pneumatic shifted gears.
But I bet most rookie teams will try to go direct drive with the drills. I always use a multi speed tranny with any motor! P.S. Anyone have a good design for a 3 speed thats Pneumaticly shifted, I can only manage a 2 speed in the given space. And Im also having a down shifting problem its a lil rough, but thats expected from helical gears right? |
#17
No....do NOT use a 3:1 reduction and call it a day
We're using similar wheels and I'm reducing the CIMs by ~20:1 |
#19
Yay, we finished mounting the motors to the 5/8" coupling gear shaft and found that we could easily hold the shaft in place and trip the fuse, so we def need more torque. 1:20 sound excesive, I'll look into a 1:8 ~ 1:12 range.
Thanks |
#20
Then, take the information you learn about speed and apply it to torque and see where you end up. Math is better than guessing. (Only marginally.) |
#21
The ratio of the speed of rotation of the powered gear of a gear train to that of the final or driven gear. |
#22
Lord,
I have to go with everyone else on this. The gear ratio sounds too high especially with the 9 ' wheels. The chalupa motors are strong but the gear ratio will allow you to go fast only if you can get the robot moving. That is a big "if" since the gear ratio will provide so little torque. 8-12 feet per second is a good guide. As to the electrical draw, the 40 amp breakers are the dominant factor and I would predict some heavy action on their part with this design. Turning will be your greatest draw. |
#23
Like I've stated before, Our Team has (somehow) managed to get 15 feet per second with a 10:1 ratio using the 2 Chiphua Motors, and we still have loads of torque. We aren't a speed based robot...
Anyway, OUr drive is really nice and (if only) if chiefdelphi had a section dedicated to video clips, I'd show you our drive in action! I might be able to get a file server and post a link in a while... Anyway, we Haven't had any issues with it, and it works great! |
| Chassis Material/Construction | sanddrag | Technical Discussion | 51 | 05-12-2003 12:59 |
| how does crab drive work? | Soukup | Technical Discussion | 13 | 25-04-2003 11:31 |
| pic: Drive System | CD47-Bot | Robot Showcase | 3 | 27-02-2003 14:11 |
| Quad- 1/2 track drive system | Ben Mitchell | Technical Discussion | 24 | 30-01-2002 11:55 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
