Go to Post Being professional means doing things right. Being gracious means doing the right thing. They complement each other perfectly. But I think we should remember to use GP as a guide for our own behavior, not as a yardstick to measure others' shortcomings. - Alan Anderson [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 24-11-2013, 16:45
bs7280 bs7280 is offline
FRC #3734
bs7280 has a spectacular aura aboutbs7280 has a spectacular aura aboutbs7280 has a spectacular aura about
What materials do you most commonly use on your robots?
the team I am on is still relatively new, we have been using the same stock material, 80-20, for basically everything we do (with a few exceptions). While 80-20 is a great material it can still be limited, bulky, and harder to work with. This year we have access to a cnc machine, lathe several mills, and a 3d printer, so we are especially interested in how we can fully utilize those tools.
What materials do other teams use or buy a lot of to use with their robots? I am especially interested in what some of the teams that regularly go to nationals use. I see some pictures of teams with early versions of robots constructed mostly out of 80/20 but then the final version seems to be something else entirely.
Unread 24-11-2013, 16:52
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: What materials do you most commonly use on your robots?
Our team personally uses a lot of aluminum box tubing and recently plenty of .125 and .25 aluminum sheet.
Generally in FIRST, you'll see a lot of aluminum sheeting of various thickness.
Academic Student (Forever)
Unread 24-11-2013, 16:58
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
We use mainly Aluminum.
For our frames, we use 1" alum box tubing (1/16" walls I think), welded into shape, which leaves an unbelievably strong and fairly lightweight piece. It is difficult to work with though, so I would not recommend our approach to a team just starting into the wonderful world of manufacturing.
On pieces that require utmost strength, like drive-train brackets and our climbing plate, we use 1/8" aluminum sheet metal, laser cut from CAD drawings and bent with a brake.
Depending on other applications, we use thinner and thinner material.
For our hopper, we used .0404, as it is very lightweight and easy to hand repair if we bashed it up a bit. For our main shooter body, we used 1/16" aluminum, which is slightly thicker, because of forces related to accelerating a Frisbee.
I think in 2011, as part of our gripper, we used .0202, but that stuff is basically paper.
For electronics, we bought a large sheet of corrugated plastic (basically plastic cardboard). You can poke through it with a screwdriver, and it is reasonably, but not uselessly, flexible. It is also very lightweight and easy to manipulate with hand tools. (on the cRIO plate in picture 1, we used a polycarb sheet for more strength.)
ID:	15448  Click image for larger version
Unread 24-11-2013, 17:02
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Your number one material will most likely be aluminum. Square tube, round tube, angle, sheet from 1/16 to .25. Then plastics (mostly sheets) UHMW, lexan, and polycarbonate are our main ones. Delrin (acetal resin) is commonly used as a bearing surface (I also like white UHMW for this). All of these can be cut on the tools you have. Also don't count out 80/20 it can be more expensive but it can be worth it.
I would advise using the 3d printer for prototyping but not anything structural.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 24-11-2013, 17:12
FRC #3734
One thing I forgot to add: For those who use a cnc milling machine, what do you most commonly use it for.
Unread 24-11-2013, 17:31
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
Here on 68 I'd say aluminum is the material we use the most. We mainly use 2X1's .125" in diameter, and 1X1's .0625" in diameter (we do occasionally use .125" 1X1s, but not .0625" 2X1's) for anything structural (chassis and supportive pieces). We'll use .0625" and .125" sheet in addition to various sizes of angled aluminum for less structural things (like the functional/moving parts in our manipulators... such as what pushed frisbees into our shooting wheel this year, and the tube that held them). There are some custom .325" thick plates in a couple places on our robot that we sent out to be water-jetted (mostly on our transmissions). We also used some Diamond Plate on our driver station and robot cart...
I've also noticed the use of lexan sheet in a lot of different places (such as the base for our electrical board, sponsor panels, guides for frisbees to fall into our disc-holding tube, and the outer wall of our shooter). I'd say that is the most commonly used material other than aluminum on my team.
As for your newer question about the use of a CNC mill, we mainly use it to accurately mill out lightening holes in chassis pieces and driver's station (only on 2X1X.125").
J Wallace IV
Truck Town Thunder
Just a college student now.
Last edited by jwallace15 : 25-11-2013 at 12:03. Reason: Correcting some off measurements
Unread 24-11-2013, 17:34
FRC #1836 (MilkenKnights)
What kind of CNC mill do you have acess to? A decent sized machine can be used to machine almost every part on your robot. Based on your resources, I would reccomend using a combination of 2"x1" and 1"x1" aluminum box tubing. Look at teams like 254, 973, and 1538 for great examples of how to use these materials.
Unread 24-11-2013, 17:35
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Virtually every part on our machines is cnc milled. We use a lot of 1x1 and 1x2 tubing along with 1x1 and 2x2 angle for brackets and the like. For sheet material we mainly use polycarb and it too gets cnc milling. For milling the polycarb sheet we use double stick tape to attach it to a sacrificial piece of particle board that gets clamped to the table.
We also use the 3d printer for a number of things. We've used it to make gears for driving encoders and we use it to make pulleys for polycord loops. They basically have a 1/2 round indentation and slip over a piece of aluminum tubing. There are little tabs on each side that we use to rivet them to the tube. Those do a great job of keeping the polycord running right where we want it. We also printed a cover for a ratchet mechanism we used for our climber which had particularly sharp teeth. We incorporated a 3d version of our bear head logo on it for decoration.
Unread 24-11-2013, 18:03
FRC #3734
A tormach cnc milling machine. Not sure what the exact table size is but it is definitely a high quality machine.
We also have access to two grizzly mills. One is a hobby/desktop mill and another is a more professional 7 foot tall mill, also grizzly. There is also a broken bridgeport mill and grizzly lathe.
Unread 24-11-2013, 18:14
scaryone's Avatar
scaryone scaryone is offline
FRC #0058 (The Riot Crew)
scaryone will become famous soon enough
Wood. Bends, before it breaks, flexes back into shape. Light weight. Plentiful and cheap. Fast curing epoxy can repair most breaks. Home depot or Lowes near most competitions.
Unread 24-11-2013, 19:20
That is a bit on the small side, but still better than nothing . With a CNC of that size, you can still do almost any custom gearbox, all your gussets, half of you box tube, and a lot of your misc. parts. The rest should be able to be done on your other equipment.
Here are some great albums showing detailed photos of 254's 2012 and 2013 robots. I would start here to find ways of incorporating your new equipment into your manufacturing process.
https://plus.google.com/115829622106274402945/posts
As others have said before, the materials that you will find yourself using most is 1"x 1" box tube, 2"x1" box tube, 1/8" plate, and 1/4" plate
Unread 24-11-2013, 19:31
GarroH GarroH is offline
AKA: Garrison Hefter
no team (None)
GarroH will become famous soon enough
We like to use a lot of aluminum, like the teams that have responded above for many of the same reasons.
One of our favorite materials, especially in the past few years, has been HDPE. This is the material we made our shooter out of and we really love it. It is fairly easy to machine and deal with. Obviously, it's not good for structural elements, but it can come in handy for a lot.
Major downside is that it can sag under its own weight. We ran into this as our shooter began to droop towards the end of the season.
Just another material to look into.
FRC 2468 2011-2014
FRC 190 2015
Unread 24-11-2013, 19:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We've used all kinds of materials....steel, aluminum, fiberglass, wood, polycarbonate, carbon fiber......
And we generally build all of it without using any numerical control equipment. A band saw and drill press, tin snips, circular saw, jig saw, hack saw, and cordless drills will do it all.
It's good to see that you figured out that 80/20 is not a very good robot building material.
Unread 24-11-2013, 20:25
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Besides the materials already mentioned, 449 tends to use a lot of delrin for many different applications. It's relatively light weight and extremely easy to machine. It is also relatively slick, so you can use it as a makeshift bearing block for low speed purposes.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 24-11-2013, 20:58
It all depends on your resources. 341 built one of the best robots in 2012 with 8020.
