Go to Post FIRST is like a big roller coaster, that can only be experianced if one takes a ride which can become a liftime experiance. - activemx [more]
Unread 23-11-2013, 21:53
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Octomecanum Shifting Question
I am currently trying to design a Octomecanum drive train for fun and possibly as a drive train for my team to use in the future and I have come to a point where I have gotten a little confused. Every example uses pneumatic cylinders to shift from mecanum to tank and I was wondering how people prevent the pistons from bending due to the stress. If anyone who has experience with this or some insight that would be really helpful.
Unread 24-11-2013, 15:45
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: Octomecanum Shifting Question
The rod of a pneumatic cylinder is more likely to bend if it experiences a side load or moment at the end of the rod while it is in its extended state. In the retracted state, the rod of the cylinder will be less likely to bend. I do not have specific experience with articulating drives, so maybe someone who does could chime in, but this might be important to consider if you are worried about bending the rod of the pneumatic cylinder. Think about which configuration the cylinder is most likely to experience side/bending loads, then make that the retracted position.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 24-11-2013, 19:04
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Are you referring to bending that would be caused by robot-on-robot impacts?
I've never built one, but in the designs that I've seen, the pneumatic cylinder would be allowed to rotate at the blind end, so that as it extends, the cylinder will rotate so that the force always goes along it's axis.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 24-11-2013, 19:24
AKA: Roger Moore
I am more concerned how people support the cylinder when it is connected to the shifting parts. What I have seen is that there is no support but I wanted to find out if that was true or if I was missing something.
Unread 24-11-2013, 19:57
CENTURION's Avatar
Two questions:
Which method of shifting are you using?
A vertical-cylinder system like this: http://www.chiefdelphi.com/media/photos/37426
Or a horizontal-cylinder system like this: http://www.chiefdelphi.com/media/photos/37096
And given that choice, what kind of "support" are you talking about? Supporting the rod? supporting the blind end? supporting the module?
Unread 24-11-2013, 20:21
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
We have used an octocanum for the past year. We used no supports on the cylinders. We have had no known bending of the shafts themselves.
Unread 24-11-2013, 20:47
Aren_Hill's Avatar
Build Nifty Things
Optimally your piston should be a simple two force member, that is, only experiencing direction extension or compression loads. Many times this is accomplished via ball joint fittings, or having enough play in its pivot that it doesn't take any load.
Keep check on load paths through the module and it should be easy enough to be sure the piston isn't taking any bending loads.
-Aren
A guy who likes robots.
Unread 24-11-2013, 22:11
AdamHeard's Avatar
Lead Mentor
-Aren
To expand on Aren's points, if the cylinders are loaded as he described the rod size is spec'd such that you won't ever fail a cylinder from it's own force.
Unread 24-11-2013, 22:33
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
-Aren
A somewhat related question: Does 148 (or neutrino) implement a encoder into their butterfly drive?
2016: FRC 865 Mentor
Unread 24-11-2013, 22:38
Aren_Hill's Avatar
Build Nifty Things
Neutrino ran last year with no sensors on the drivetrain, but still had a 7 disc auto
Unread 24-11-2013, 23:18
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Did they just do gyro PID and then drive for set times?
-Plutarch
Unread 24-11-2013, 23:30
FRC #1836 (MilkenKnights)
I doubt they used gyros. Their butterfly allowed them to drive straight without PID.
