Go to Post So take it all with a grain of salt, form your own opinions, lead by example, act responsibly, be graciously professional, and everything will be ok. - LauraN [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
  #32   Spotlight this post!
Unread 25-11-2013, 00:11
BurkeHalderman's Avatar
BurkeHalderman BurkeHalderman is offline
Casual Robot Observer
BurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant future
Re: What materials do you most commonly use on your robots?
Originally Posted by Oblarg View Post
This does not offset the fact that by far the single largest source of mechanical failures I have witnessed on our robots, both directly and indirectly, has been 80/20 construction. I have not seen those same mistakes made with tube/gusset construction, simply because the modes of failure I've seen most often are simply not possible with tube/gusset construction.
Can you describe these mechanical failures that were caused by using 80/20?
Originally Posted by MichaelBick View Post
How is it possible to make more mistakes with 8020 if you build in a very similar way, however without gussets?
I'd assume it'd be due to parts shifting in the T-slot profile. However if you simply drill through the 80/20 after positioning it using the T-slot then the problem is resolved.
[2010-2014]: FRC 3266 Robots-R-Us: Founder and Alumni
2010 (5-5-1): Buckeye Regional; Driver
2011 (4-5-0): Buckeye Regional; CORI; CAGE Match; Drivetrain/Manipulator Operator
2012 (7-13-0): Buckeye Regional; Queen City Regional; CAGE Match; BPRC; Drivetrain Operator
2013 (25-15-1): Queen City Regional; Buckeye Regional; Crossroads Regional; CORI; Ohio State Champs; CAGE Match; BPRC; Drivetrain Operator
2014 (21-10-0): Crossroads Regional; Queen City Regional; Designer; Mechanical/Design Mentor
Founding an FRC team as an 8th grader sure wasn't easy, but it was totally worth it.
Get in touch with me:
Personal Facebook
I believe every human has a finite number of heartbeats. I don’t intend to waste any of mine. – Neil Armstrong
