Go to Post Glue it, screw it, bolt it, rivet it, weld it. If the design is flawed it will fail. - Gdeaver [more]
Unread 25-11-2013, 12:07
xForceDee's Avatar
xForceDee xForceDee is offline
AKA: Bart Kerfeld
FRC #4239 (Warpspeed)
xForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to behold
Wheel Diameter of Mecanums
During my experience with FIRST, I have observed teams using several different wheels for their drive trains. One thing I have noticed is that teams with mecanum wheels generally choose large diameter wheels (8" or above) while teams with non-mecanum wheels choose generally smaller wheels (4"-6"). I am wondering what the reasoning behind this is. Obviously if you can get the same angular velocity on a larger diameter wheel, then that results in a greater linear velocity of the robot but besides that, I don't understand the advantages of choosing larger wheels, specifically the reason for not choosing the 6" versions offered by Andymark and Vex. Does the size increase improve the mecanum's performance in some way? Do smaller mecanum wheels have a greater tendency to break?
Unread 25-11-2013, 12:11
Oblarg Oblarg is online now
AKA: Eli Barnett
Re: Wheel Diameter of Mecanums
Having used both 6'' mecanums and 8'' AndyMark mecanums extensively, I've had far better results with the former, both in terms of performance and quality of the product.
I don't know why anyone would specifically go for larger mecanum wheels; this past year 4464 used 8'' AndyMark mecanums because they were donated, but we honestly would have done better to just buy a set of 6'' given the problems we've had with them.
I look forward to trying out 4'' mecanums (probably in an octanum setting) when they (likely) become available.
"The breakfast of champions!"
Unread 25-11-2013, 13:29
Could you please give more detail about what you mean by performance and quality in this context?
What kind of problems did you have with the 8" wheels that you did not have with the 6" wheels?
Unread 25-11-2013, 14:02
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
We always used 6" mecanums. Even in 2012 while crossing the bump. They are by far and away lighter and massively smaller profile than the larger variants. The large mecanum wheels also don't look near as cool
Unread 25-11-2013, 14:09
AKA: Eli Barnett
In my experience, 6'' wheels run smoother (less vibration) and track straighter while strafing (in the absence of a gyro).
We also had several defective 8'' mecanum plates, and one of the backup wheels we purchased was so deformed that not a single roller could turn since they were all in contact with their neighbors. They're also heavier, and the rollers jam far more often.
I've had no quality problems with the 6'' models, ever, nor any major issues with their performance since 2008 (when the plate was flimsy and required constant maintenance to keep it from bending in on the rollers).
Unread 25-11-2013, 15:48
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
I'd just like to add my two cents on this.
We used 8" AndyMark mecanum wheels in 2010. We wrecked two sets over 7 events, after the constant bashing from climbing over the bump. I have no comparison for the 6 inch, as we didn't try those, but draw your own conclusions about the 8" wheels' durability.
Can anyone attest the the 6" VexPro mecanum's durability as opposed to the AndyMark ones? We'd like to try those this year.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 25-11-2013, 16:14
I am Dave! Yognaut
AKA: Brian Bray
In 2011 we used the standard AM 6" mecanum wheels. In 2012, we used the HD wheels, due to the bump and related forces (even though after calculations, the standard wheel specs would not have been exceeded). After 2 regionals and an offseason, and extensive testing (our first year using mecanums) in 2011, we did not, and still to this day, have not replaced any of the rollers on the wheels. On our 2012 robot, after our 2nd regional we had to replace about 10 rollers, some from each of the 4 wheels. This was probably not due to any difference between the standard and HD wheels, but likely due to slight skidding on the ramps and testing on linoleum floors that wore down the rubber rollers over time.
I have not used any VexPro mecanum wheels, but I would trust the construction of the plastic plates, because of the rigidity other plastic VexPro products (ballshifter housing, versa-wheels). I do not know about the rollers on those wheels, but if they are similar in tread to a Versa-wheel, I would be careful and monitor the tread wear on your mecanum rollers. Damaged and missing tread will cause your robot to "hobble" as it bounces every time the wheel reaches the missing spot. Remember, a mecanum wheel is not a circle, it is a N-gon. With a missing vertex, irregularities occur. This will make actions such as strafing behave a little weird.
Unread 25-11-2013, 18:34
Could you please describe in a bit more detail what you mean by "wrecked"?
e.g. the plates got bent, or the roller axles got bent, or the rollers got chewed up, etc
Unread 25-11-2013, 18:39
It is possible to design a mecanum wheel whose profile is a true circle. For anyone interested you can find more info here, here, here, here, and here.
Unread 25-11-2013, 18:58
yash101 yash101 is offline
AKA: null
We used the 8-inch AndyMark ones and we were impressed. The wheels allowed us to not only move nicely and freely, but also allowed us to push other robots and sideload them! Our drivetrain was quite effective. On the other hand, I saw many teams with ginormous mecanums. I, myself, cannot understand why they did that. It only seems like more weight and it takes a lot of room!
Unread 25-11-2013, 19:09
MichaelBick MichaelBick is online now
FRC #1836 (MilkenKnights)
Originally Posted by yash101 View Post
We used the 8-inch AndyMark ones and we were impressed... On the other hand, I saw many teams with ginormous mecanums. I, myself, cannot understand why they did that. It only seems like more weight and it takes a lot of room!
Why didn't you use 6" mecanums then?
Unread 25-11-2013, 19:13
I am Dave! Yognaut
AKA: Brian Bray
This is true. And the VexPro wheels are a good example. The problem arises when one (or more) rollers is removed (physically or due to wear), suddenly you have a round wheel with a flat spot. Like a train wheel.
(someone had a bad day)
Unread 25-11-2013, 19:21
AKA: null
Talking Re: Wheel Diameter of Mecanums
Well, we tried the 8 inch wheels and they went past our expectations. So, we just stayed with that!
Also, how does that happen to a train wheel? Does it go, Thump...Thump...Thump...?
Why is it red hot?
Unread 25-11-2013, 19:23
AKA: Eli Barnett
Having used both, I would recommend you at least consider the 6'' models, if only for the significant weight decrease.
Unread 25-11-2013, 19:25
AKA: null
I will talk to our team captain about that!
The funny thing is that every Wednesday (robotics day), I enter the classroom and blast the mentor and the captain with outrageous ideas. That's just me, the curious one
