Go to Post They can either incorporate the suggestions in this thread, go totally against them, or even make us all write code on banana peels with our fingernails. - Andy Baker [more]
Thread Tools Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Unread 25-11-2013, 14:22
Brandon Holley's Avatar
Re: Practical 3D printed parts
Originally Posted by sanddrag View Post
Brandon,
I'd really be interested in more details of the urethane pouring process and pictures of the mold, as this is something I've never done. Your finished product looks good. I'm also interested in seeing the 3D printed FP gearbox if you have a picture.
Thanks.
I've got plenty of pictures back on my home PC- I'll circle back tonight and post them.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 25-11-2013, 19:01
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Just in this one picture there are many 3D printed parts:
- wheels on end of arm that set floor height.
- bearing blocks on active leading edge (inside wheels)
- finger grippers on 3/8" round, keyed shaft
- crowned flat belt pulley on keyed 3/8" shaft (under flat belt)
- finger grippers on 1/2" hex shaft
- bearing blocks on main arm pivot
- drivetrain gearbox dust covers (near side yellow, far side purple)
- camera/light ring mount (purple, on underside of shooter)
We're to the point now where we'll make just about any nonstructural part with the 3D printer rather than spending fab time to make it. Thus far, we haven't broken any plastic parts. The bearing blocks were an experiment to see if semi structural parts could hold up if made beefy. These have lasted through two off-season competitions and at least half a dozen demos.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 25-11-2013, 19:15
Oblarg Oblarg is offline
AKA: Eli Barnett
What material do you use?
"The breakfast of champions!"
Unread 25-11-2013, 21:33
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
Here's a project my senior students worked on. I don't have access to the printed part (at school right now and I'm home), but the second one fit extremely well to a VEX Versa hub. The original intent was for our 6 WD test bot and the driven wheels would used this design. Last year's bot used an 8" drive wheel and 6" driven wheels, but we used chain drive. This year we want to use belt drive and we couldn't find the tooth ratio we wanted so we started to draw this in Inventor. The tooth profile wasn't too hard to get, but the hard part was getting the right diameter for the circular pattern of the tooth to work out in Inventor and in real life. So, this one is 39 tooth to match the Andymark double pulley, so if we use this design, wheel sizes will be common. But I'd like to cheat the driven ones to be smaller to increase the wheelbase of the bot. Therefore we redraw it with the right tooth ratio and off we go. The problem will be getting a smaller tooth profile to fit with the part. If we keep the 39 tooth drive with a 6" wheel, we need a 26 tooth driven for a 4" wheel. Not sure how that 26 tooth will match up with the Vex Versa Hub Pattern. But in the classroom that becomes an absolutely great design exercise to go through!
BTW, Project Geometry is your very good friend in Inventor. Just make sure you have the parts in an assembly, constrained correctly, and then you can modify the part you are working on to match very, very well with the mating part.
Name:	39 Tooth Pulley - Vex.jpg
Unread 25-11-2013, 23:13
yash101 yash101 is offline
AKA: null
ABS is a very nice plastic and is very strong. After 3D printing technology improves enough, it will be feasible to start producing things like pulleys and other highly used parts. Pulleys should already be an easy one to 3D print as long as you use an aluminum or steel axle because the load is distributed throughout, reducing the stress on the plastic!
I have gotten many things printed in ABS. They are very strong, and lightweight and take compression forces quite well, as long as there is no sheer or bending force on it. My Stirling Engine crankshaft broke because of the high sheer force I accidentally placed on piece, when removing the building material. I should have used an abrasive instead, to get rid of the black building material.
Our school has either 2 or 3 of those Dimension 1200ES printers! Out of that, we use only one!
Unread 25-11-2013, 23:32
Bald & Bearded Bald & Bearded is offline
Jack of All Trades/Master on none
FRC #1885 (ILITE Robotics)
Bald & Bearded is on a distinguished road
Lots of good examples out there. I am impressed with everything Triple Helix has done with the parts.
Last year we had only started getting into printing. On the robot we printed a couple of things. One was some bushing which fit inside the outer tube of our lift and let the inner tube slide up easily. We also, printer out our gyro holder and some thin flexible fingers for our shooter to help keep the frisbees aligned.
Oh, and we printed out a bunch a little key chain wrenches to hand out.
This year we are looking for opportunities. I can certainly see some manipulator parts depending on the game this year.
For FTC we have a couple of teams already doing some things. One team CAD'd and printed flippers to pull the blocks into their bot. We also had some of the old clip style samanthas so one of the kids found a CAD of the back and we added some bolt down tabs. (Pic attached)
We also started experimenting with plastic parts with hole textrix hole patterns. Specifically to get different heights through different thicknesses (pic attached).
As another poster commented layer separation can be a problem. For other projects at home (like the robot hand I posted earlier on another thread) I have used acetone painting and acetone vapor baths (safety is a huge consideration). Other than that though ABS is very strong. Even with 20% honeycomb in-fill and 3 shells the parts I have printed are very strong. Just look at how well the 3d printed extruder gears on RepRaps hold up. The one on my Prusa I2 has thousands of hours on it.
The other issue mentioned is print time. I have had parts take 6-8 hours to print (parts of the robot forearm) and an hour or so is not un-heard of and you will have failed prints usually after half the print. If you have other CAM capabilities (CNC mill, laser cutter, etc.) they can be much more efficient. And yes the commercial printers generally can be run faster than the RepRaps we use but for complex prints.
The other big limitation is build area. The printers we use have an effective build area of 180mm x 180mm x 170 mm. So you may need to cad bigger things as separate parts that can be joined. ABS glues very well with Acetone and bolts are easy.
I really look forward to seeing what neat ideas teams come up with. I hope to see more threads like this one. Maybe, we should look at tagging FRC and FTC parts when posted on Thingiverse or having a standard thread hear on CD so folks can always see what is new.
Name:	2013-11-25 20.34.36.jpg
ID:	15461  Click image for larger version
Name:	2013-11-25 22.13.35.jpg
Unread 25-11-2013, 23:34
Cool stuff. Can you post some close ups and/or STLs of these parts?
Oh, and what kind of printer do you guys have?
Unread 26-11-2013, 15:48
Rohawk1's Avatar
Rohawk1 Rohawk1 is offline
MC and GA :D
AKA: Patrick Jung
FRC #3824 (RoHAWKtics)
Rohawk1 will become famous soon enough
Hi! I'm from FIRST team 3824, and we have been working with Oak Ridge National Laboratory for the past four years. Two years ago, we had the very first all-printed robot. Last year, we had a printed robot with carbon fiber. We definitely have benifitted from the use of 3D printing, and we are partnering with 3D Systems on the development of a new website for FIRST. It will have the ability to upload and download parts designed specifically for the kit of parts. This will enable us to help new teams take advantage of the technology and also share models.
Another use of these printers is fundraising. You can make and sell trinkets, keychains, cell phone covers, etc. to make money for your team. I believe this will be the most useful tool your team will ever have. You can make customized cell phone covers for a few dollars and sell them for $20 to $30! Last year we helped make Frisbees to give out at Nationals and the Smoky Mountain Regional (SMR). I'll start uploading pictures to get teams thinking.
We even have a tagline that is 3D printed which says "Made in America" in Chinese. So, be creative in how you use the printers beyond just making parts for your robot
Unread 26-11-2013, 15:52
Rohawk1's Avatar
MC and GA :D
AKA: Patrick Jung
Here's an example of a printed belt pulley that interfaces with an AndyMark shaft hub. This will let you make any sized belt pulley. We will start uploading these models to 3D Systems' FIRST website.
Unread 26-11-2013, 15:54
Rohawk1's Avatar
MC and GA :D
AKA: Patrick Jung
Here's an example with some printed brackets connected by carbon fiber rods. We used this on our robot last year.
Unread 26-11-2013, 15:56
Rohawk1's Avatar
MC and GA :D
AKA: Patrick Jung
Here is a picture of our printed robot from last year.
Name:	FY13 Robot.jpg
Rohawk1's Avatar
MC and GA :D
AKA: Patrick Jung
Here is our printed robot from two years ago also
Name:	FY12 Robot.jpg
Unread 26-11-2013, 16:00
Jared's Avatar
Jared Jared is offline
Our printer was really useful this year.
Name:	3d print.jpg
The banebots motor mount was 3d printed, the pulley that is on the banebots motor was 3d printed (it fits over the gear on that motor), the pulley on the shooter wheel was 3d printed, and the shooter wheel itself was 3d printed. We had made some shooter wheels out of HDPE, but as they were cut they would warp because of internal stresses from the manufacturing of the plastic. The 3d printed wheels were perfectly balanced and improved our accuracy.
The 3d printed big pulley was printed in 12 hours because we didn't want to wait for the order to come in. The little pulley was the most useful because of the gear-shaped hole in the back. Originally, we tried "modifying" the 4:1 P60 gearbox to become 1:1, but it was inefficient. The 3d printed pulley let us interface directly with no transmission relatively easily.
Unread 26-11-2013, 16:41
Are these parts printed in Ultem? Looks like you had some serious access to a Fortus machine!
-Brando
Unread 26-11-2013, 16:49
Rohawk1's Avatar
MC and GA :D
AKA: Patrick Jung
-Brando
Yes they are! We have the privelege to work with Oak Ridge National Laboratory, so we have the ability to print with Fortuses. We allow teams in the area to print things as well, so we're not selfish with this technology. It is always better to have more collaboration with other teams.
