Go to Post I think we sometimes forget that FIRST is not just about building robots. Its purpose is to educate and inspire young people in the field of science and technology. - amanda [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 25-11-2013, 00:23
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Re: What materials do you most commonly use on your robots?
Originally Posted by mman1506 View Post
Any ideas for what to do with these 3/4 to 3 inch thick sheets of scrap T6 hardened 7075 aluminium we were donated?
https://fbcdn-sphotos-d-a.akamaihd.n...86326484_n.jpg
We've been thinking of making a 7075 belly pan
That is a nice chunk of scrap. Perfect for FRC sized parts.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
  #32   Spotlight this post!
Unread 25-11-2013, 00:33
Oblarg Oblarg is offline
AKA: Eli Barnett
Holy crap, that's a lot of metal.
Got a CNC mill?
"The breakfast of champions!"
  #33   Spotlight this post!
Unread 25-11-2013, 00:45
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Got a CNC mill?
We do
2016: FRC 865 Mentor
  #34   Spotlight this post!
Unread 25-11-2013, 00:51
AKA: Eli Barnett
Originally Posted by BurkeHalderman View Post
Can you describe these mechanical failures that were caused by using 80/20?
I'd assume it'd be due to parts shifting in the T-slot profile. However if you simply drill through the 80/20 after positioning it using the T-slot then the problem is resolved.
You're correct in your assumption. The problem, and it is a pervasive problem, is that in the rush of build season, taking apart everything and through-drilling all of the 80/20 parts that need to be through-drilled simply doesn't end up getting done - human psychology being what it is, I've simply noticed that it's not at all hard to leave something improperly constructed and sloppy on an 80/20 frame where, at a glance, it seems functional. Building final versions out of other materials ends up being lighter, not much more work, and ensures that everything ends up rigid and fixed in place.
If students (and mentors) were perfect, this would not be an issue, but as I mentioned earlier I feel it's as much a pedagogical concern as it is a functional one. I (and the rest of my team, from what I recall) got into a bunch of nasty habits in my early FRC years with 80/20 construction that took a while to break. I feel it is far safer to avoid them entirely.
I do think we probably ought to wrap this exchange up, lest we fully derail the thread; we could start another, if you'd like to continue discussing it.
We do
Then the possibilities are endless!
  #35   Spotlight this post!
Unread 25-11-2013, 10:44
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Just to keep with my team's namesake...
PVC tubing is very effective when you need a lightweight material for arms and other manipulators. It also makes an efficient roller or spacer.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
  #36   Spotlight this post!
Unread 25-11-2013, 11:06
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
The 1" square profile, at .59lbs/ft is barely heavier than a 1" square, 1/8" wall aluminum tube at .524lbs/ft. So no it is not heavy. If you use 80/20 with an absurd amount of gussets then yes your robot is going to be heavy, if used properly it is not heavy.
I have never seen a team use .125 thick 1" tubing. Everyone I've seen (including our team) uses .0625 (1/16") wall thickness, which, without running numbers (or Google-ing), should end up roughly 1/2 that weight per foot.
  #37   Spotlight this post!
Unread 25-11-2013, 12:26
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
I like using 80/20 for chain and belt tensioning, easy way to move the belt around and loosen then tighten it. Did this to tension our shooter arm pivot chain last year.
PVC tubing is always great to make spacers and as a circular form of shielding.
I havent gotten into carbon fiber construction in any robot's I've mentored teams for yet, but we have the resources to do so this year so it may be fun to try. I have personally done CF layups (both vacuum seal + autoclave and wet) so have some experience with the process. Just gotta get the students on-board first.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
  #38   Spotlight this post!
Unread 27-11-2013, 20:19
Celia's Avatar
Celia Celia is offline
Now I go to college
FRC #0240 (TEMPEST alumna, MEZ mentor)
Celia is an unknown quantity at this point
240 tends to use aluminum tubing, polycarbonate, and wood for general constructions. As previously stated, we like PVC for spacers. It seems like these are the go-to materials for many teams. However, we're testing out some corrugated plastic soon, so maybe that will be added to the list
See one, do one, teach one
  #39   Spotlight this post!
Unread 27-11-2013, 20:35
Jared's Avatar
Jared Jared is offline
We used it this year on some frame parts and our climber mounts, but we think we could have gotten away with the thinner stuff. When we fell of the tower we had a weld snap before the box tubing bent. We also have a TON of it in storage, so we'll probably end up using it again.
  #40   Spotlight this post!
Unread 27-11-2013, 20:41
Pendulum^-1's Avatar
Pendulum^-1 Pendulum^-1 is offline
AKA: Jim Grove
FRC #1915 (Firebird Robotics)
Pendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nice
Mostly aluminum. Our chassis is typically c-channel, and the superstructure is a lot of 8020. If anyone is using 8020, I highly recommend that you use their " end fasteners." Very lightweight and strong way to make right angle joints in 8020. Ok, so you have to do a little work and tap the ends of the extrusions. Nearly everyone on our team knows how to tap metal now! Oh, and in order to get good 90 degree joints, you really need to have a very good miter saw with a non-ferrous metal blade to cut the 1010 extrusions very cleanly, very accurately. A band saw or hack saw, in my experience, will not do.
We also use a fair amount of polycarbonate. We either use the AM perforated sheets (to mount electrical components) or multi-wall polycarbonate, which is exceptionally strong and light, useful for mounting very light components, or as a modest armor plating, to prevent incidental intrusions of other robots/game pieces to interfere with our robot's internal wiring. We will typically buy a sheet, and have it cut to 2'x4' to ship it cheaply.
Steel pillowblocks, various components from AndyMark, VexPRO, and/or McMaster Carr typically comprise the rest of our robots.
For us, with very modest machining capabilities, simplicity of fabrication is paramount.
Jim Grove, Mentor
firebirds1915.blogspot.com
(2007-2017) 1915, McKinley Tech HS, Washington, DC
(2009) 2932, Mid-Pac Institute, Honolulu, HI (Rookie Season)
(2011) 2425, Hillsborough HS, Tampa, FL
(2013-2015) 4464, College Park, MD, 2013 Rookie All Star Winner and 2014 Regional Champions, Washington, DC
FIRST is not rocket science. But it is like drinking from a fire hose.
  #41   Spotlight this post!
Unread 27-11-2013, 21:59
Rohawk1's Avatar
Rohawk1 Rohawk1 is offline
MC and GA :D
AKA: Patrick Jung
FRC #3824 (RoHAWKtics)
Rohawk1 will become famous soon enough
Last year, we integrated a mixture of 3d printed Ultem and Titanium into our robot. We also used woven carbon fiber structures for the chassis. Our robot was light, yet extremely strong.
  #42   Spotlight this post!
Unread 02-12-2013, 07:02
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
FRC Team 1501 T.H.R.U.S.T. uses .062 aluminum sheets and just a few rivets
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
  #43   Spotlight this post!
Unread 03-12-2013, 16:57
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
*small voice*
In 2012, 1370 built their frame out of 2"x1" aluminum box with 1/8" walls. We then bought a 1-3/8 hole saw and had students use our Bridgeport vertical mill to lighten the aluminum parts at very precise repeated intervals. The end result was a robot which was 119.9 pounds without a shooter.
Of course, that also meant we could balance with anybody on the bridges and we could move any fender-shooters off their mark without any real effort....
In 2012, we used 1" square 1/16" wall aluminum box tubing and worked up a pretty decent offensive robot.
Moral: Never using 1/8" wall aluminum tube again.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
  #44   Spotlight this post!
Unread 05-12-2013, 17:17
FS Robotics FS Robotics is offline
FRC #5119
FS Robotics is an unknown quantity at this point
I am on a FIRST Rookie team and have a question about supplies. Are there any parts and tools that my team will definitely need during build season that does not come with the Kit of Parts? We would like to purchase these before build season if it is possible, but have no idea what items to buy.
Thank you for your help!
  #45   Spotlight this post!
Unread 05-12-2013, 17:59
The KOP only gives you a basic drivable base, so there is a lot more you'll need to beg, borrow or buy.
You'll need raw material for any superstructure/manipulators/mechanisms, additional speed controllers to control any motors beyond the basic drive motors that you'll get.
You may need to purchase extra 12v competition batteries, more (FRC legal) motors, nuts & bolts, rivets, tools, the list goes on for quite a while.
If you have a nearby veteran team then visit them to look at last year's robot. or find photos online of robots. Most of what you see will need to be added over and above what the Kit supplies.
You may not know what all you may need until the game is revealed and you settle on a robot design.
