Go to Post It always surprises me how many teams wait until their robot is being inspected to learn how files should be used. - Richard Wallace [more]
Unread 27-11-2013, 22:37
ArzaanK ArzaanK is offline
FRC #1325 (Inverse Paradox)
ArzaanK is an unknown quantity at this point
Problems deploying code
Hi everyone,
First of all, I would like to apologize if this problem has been addressed before. I searched the forums, and found similar issues, but none that matched my exact problem.
This year, our team has started our shift to C++ from LabVIEW. I installed Windriver exactly as stated in the WPI guide. I also installed the update called "WPILibC++Source20130302rev3622". I have tried completely uninstalling and re-installing Windriver multiple times following the instructions in the WPI guide to a tee.
However, I have a deployment problem. I wrote some simple code that drives the robot, controls a relay and does some very simple autonomous movement. I built the project without any errors. Then, I went to Window -> Preferences ->FIRST Downloader Preferences and set my team number to 1325 and set the file to download the robot to
C:\WindRiver\workspace\SimpleTemplate\PPC603gnu\Si mpleTemplate\Debug\SimpleTemplate.out
(My robot project was left at the default name of Simple Template)
After that, I plugged in the Ethernet cable into Slot 2 of the cRio (slot 1 does not work), and plugged the other end into my laptop. I then proceeded to disable my wireless card in the network and sharing centre and changed the settings of my local area connection as follows:
IPv4: 10.13.25.6
DNS: 255.255.255.0
I then pinged the cRio to make sure the connection was established. I got four replies in less than 1 ms, multiple times.
Next, I clicked FIRST -> Undeploy to undeploy any code from the cRio, I then opened up the driver station to make sure there was no code running on the cRIo.
Then, I clicked FIRST -> Deploy. However, I don't get a progress bar. I just get a message box saying "Downloading to robot" without a progress bar. Also, on the bottom right hand side of the screen, there is no progress bar there either. If I leave it, it will stay on that screen, and I won't even get an error message.
Please see the attached screenshot to get a better idea of what I'm trying to say:
In case you cannot view the screenshot, here is a link to it.
http://imgur.com/XDCodZ3
After going through the process I mentioned above multiple times, I then decided to take my project over to another students laptop and deploy the code from their laptop. When I tried it on that students laptop, everything worked fine, and I followed the exact same steps that I did on my laptop.
I have no idea what is wrong, and and help would be greatly appreciated.
Thank you,
Arzaan Khairulla
Programmer/Driver
2013 Greater Toronto Regional East Winners with 1114 and 2056
2013 Galileo Division
