Originally Posted by MetalJacket
Just to clarify for my own knowledge, there should be little to no performance issues using 9mm wide belts compared to using 15mm wide belts (like those in this year's KoP) assuming they both have the same tooth profile? I'm currently working on a practice sheet metal chassis using belts and I'm trying to make the wheel wells as thin as possible but I don't want to compromise performance for space. Thanks,
Jesse
Not necessarily true. The maximum torque that can be put on a belt varies proportionally to its width. If you're right on the edge in terms of how much torque that can be on the belt, the switch from 15mm to 9mm definitely makes a difference in whether it will ratchet or not. If you want to be sure, check the Gates website. They should have some nice tables that give all of the relevant torque and speed information.
Just keep in mind that for FRC, your FoS or duty rating will probably be much lower than 1 (i.e., it can take more torque than what's on the table). Those belts are designed for hundreds of thousands of cycles, something they'll never see in FRC, so we can probably get away with more torque than they were designed for. Adam Heard probably has a more exact number, as he's built a lot of belts drivetrains before.
