Serial Shortening
Is it legal to cut the serial cable connecting radio to the RC and shorten it? I thought I saw a rule that said it was legal to shorten/lengthen some wires, but I can't find it now. Thanks in advance.
I wouldn't go to the trouble of actually cutting the cable, I would just get a shorter one or tiewrap the slack or something...
Clearly, if I had any sense at all, that's what I would do. But instead, I feel like creating extra work for myself. It's not like I don't have enough work already, it's that I behave in nonsensical ways. I'm compelled to cut the serial cable to make it the perfect length. The manual says it's acceptable to shorten/lengthen Control Cables with 3 conductors or fewer such as PWMs as long as the connections are insulated.
if your still tracking this thread, we had the same issue, i simply wired a strait-thrugh 9 pin cable with a male and female DB9 from radio sha... I MEEN DIGIKEY! anyway it works fine, but if they make us take it out for the compitition we have a premade backup... - JACOB
make your own. its much prettier than having a splice in the middle of the premade ones.
Re: Serial Shortening
Re: Re: Serial Shortening
| Win32 serial port - recieve buffer | seanwitte | Programming | 4 | 05-11-2003 21:41 |
| How to communicate both through radio and serial port? | JC Denton | Programming | 1 | 08-02-2003 23:43 |
| Problem with communicating with STAMP through serial port | Skabana159 | Technical Discussion | 2 | 06-02-2003 21:10 |
| Ever seen this serial port problem before??? | Aidan F. Browne | Programming | 5 | 05-02-2003 12:03 |
| FOR SALE: Long serial cables Cheap!!! | sanddrag | General Forum | 10 | 06-11-2002 15:39 |
