Re: multi booting
What software do you use for virtualization? I would like to use virtualization instead, but don't know where to start!
Re: multi booting
I use virtualbox and it works really well. When our team's programming laptop broke, I used my linux laptop that was running windows xp in a virtual machine to run the robot.
Re: multi booting
Oracle VirtualBox works great but be aware the keyboard in the virtual machine is a little messed up in the last few versions. It does not always have a noticable effect but the inter-character timing is not quite correct. Resulting in some seemingly random behavior. |
Ok. I thought by virtualization, you meant that you switch OSes by using a command or something. There could be some sort of host OS that requires a few MB of RAM, and barely any CPU. The RAM could be rationed and divided, or maybe even dynamic (One OS requires more RAM than other, so the one requiring more get's more)!
I use virtualbox. However, I haven't been able to boot Ubuntu on Virtualbox. My Processor is an i3-2367, so it isn't ideal for virtualization (lowest end processor that Intel manufactures, except celerons). My BIOS says that it supports virtualization. However, I am only able to boot 32-bit Debian! I should be able to install 64-bit Debian. I want to install Ubuntu, however, it always says that I have an i686 processor, so I am using the wrong kernel! What do I do? |
Re: multi booting
I use Hyper-V (part of server 2008), and VMware.
#7
Re: multi booting
I used to use Hyper-V, but I downgraded from 8 Pro to 7 Home. It useed to work well, but Windows 8 just got my nerve because I don't have a touch screen
