Go to Post If I can make one wish, it would be having Dean and Woodie read one of these writings of mine, so I can tell them "I get it! Give me time and give me inspiration, and one day I will be ready to take over the torch." - Ken Leung [more]
  #31   Spotlight this post!
Unread 29-11-2013, 14:29
Re: Galileo - The Champion's Division
I think any attempt by FIRST to sort divisions by some sort of competitive metric will be a complete failure; FIRST simply isn't tuned into that kind of stuff.
Remember a few years ago when they tried to "balance" quals by sorting teams into three groups.
Who do you mean by "they"? I don't think you can blame FIRST for the Alliance Algorithm of Doom.
  #32   Spotlight this post!
Unread 29-11-2013, 14:37
AdamHeard's Avatar
Lead Mentor
That is a separate failure, and I believe only affected week 1 regionals? The alliance of doom looped you against the teams immediately adjacent to you in team number if I recall correctly.
  #33   Spotlight this post!
Unread 29-11-2013, 15:24
Chris is me's Avatar
AKA: Pinecone
This old post by Dave Lavery might be relevant to your discussion of the 2007 match algorithm. Apparently the algorithm designers essentially decided independent of FIRST what their priorities in assigning partners were. It seems like this post is referencing both the week 1 clustering of teams and the general "low / mid / high number vs low / mid / high number" algorithm. Apparently the latter was never fixed in 2007 despite FIRST's requests.
  #34   Spotlight this post!
Unread 29-11-2013, 18:22
As I recall, the Algorithm of Doom was exactly what Alan said it was. Now, some of the events MAY have had the result you described--but that was due to being smaller events.
Typical Algorithm of Doom match would be that you were against one or two really good teams for half your matches, and never with them.
FIRST did release a fix, but it took a few weeks and didn't do much for smaller events, IIRC.
  #35   Spotlight this post!
Unread 29-11-2013, 18:23
AdamHeard's Avatar
Lead Mentor
http://www.chiefdelphi.com/forums/sh...6&postcount=32
  #36   Spotlight this post!
Unread 29-11-2013, 18:44
Sorry, Adam, but you're not adding anything new. If you have new information that you didn't ALREADY state (and which I was responding to). The discussion I remember applied the term "Algorithm of Doom" to the 3-group qual setup system, partly because if you were in the same group as [insert powerhouse] you would never be with them, and probably be against them 3 or 4 times. It wasn't fixed. IIRC, there was some modification AFTER a few weeks that was a slight improvement, but not enough to make much difference.
You may be thinking of 2010, where there was a change to the seeding structure after Week 1 produced a number of 6v0 matches.
  #37   Spotlight this post!
Unread 29-11-2013, 19:16
AdamHeard's Avatar
Lead Mentor
Week 1 of 2007 the doom scheduler had you play with/against the team above or below you in team number every match.
Later in season, Champs for sure, teams were clearly lumped into 3 groups (in order of team number) with each qual alliance having a team from each group. Punishing low number teams that were not elite, and favoring high number teams that were elite.
  #38   Spotlight this post!
Unread 29-11-2013, 19:30
Didn't remember the first part. As a matter of fact, this is the first I remember hearing about it. What I remember is the 2nd part being throughout the season--and, as a note, the 1st part could be an artifact of the 2nd part, to an extent.
  #39   Spotlight this post!
Unread 30-11-2013, 13:59
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
One interesting Einstein winning alliance was the IFI alliance in 2008.
1114
217
148
It was all coincidence how it worked out.
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
  #40   Spotlight this post!
Unread 30-11-2013, 17:24
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
Originally Posted by DampRobot View Post
Fair enough. I'll give you that OPR was quite good last year. On the other hand, there were some years (like 2012) when it was absolutely terrible. Personally, I like OPR a fair bit, but it certainly can't tell you all there is to know about a team, and often tells you significantly less than what is important (at least, important for alliance selection).
I was commenting more from the perspective that there seems to be an irrational hatred of OPR among some veteran members of the FRC community, and that those people might be against a metric like OPR controlling divisions.
I agree, opr is often not well received, and understandably so. It's not the best, or most accurate metric, but it's better than whatever they currently use and arguably the best option that can be used to measure every single team in frc since I doubt we can get real scouting data on every single team.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
  #41   Spotlight this post!
Unread 30-11-2013, 17:34
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is online now
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Check out 114's schedule at PNW 2007: http://www.thebluealliance.com/team/114/2007
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
  #42   Spotlight this post!
Unread 30-11-2013, 17:37
AdamHeard's Avatar
Lead Mentor
It also only existed at week 1 events, and wasn't an issue at week 2. I remember this very well as we would either have played 254 or 330 in every single match, and that didn't happen.
  #43   Spotlight this post!
Unread 30-11-2013, 17:41
We had that issue at Trenton in 07.
Check out who we played a bunch!
http://www.thebluealliance.com/team/11/2007
  #44   Spotlight this post!
Unread 30-11-2013, 18:02
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
I remember that issue! At GSR, 1058 played 1073 every single qualification match with 1277 bouncing between alliances.
It was such a shame because both were fantastic machines that would have done better if they didn't have to play each other every match.
1058 PVC Pirates 2016 - xxxx
  #45   Spotlight this post!
Unread 30-11-2013, 18:09
DampRobot's Avatar
Physics Major
AKA: Roger Romani
192 much?
-Plutarch
