Go to Post dang. I wish my legs were as good as Dave's. - Amanda Morrison [more]
Unread 06-10-2013, 19:12
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Rapsberry Pi cRIO Integration
Is it possible to integrate the raspberry pi on our robot so that it works with the cRIO. We use java to program our bot.
Unread 09-10-2013, 12:11
MrTimKlein's Avatar
MrTimKlein MrTimKlein is offline
Mentor - Programming, Electronics
AKA: Tim Klein
FRC #3966 (STEMpunks)
MrTimKlein is an unknown quantity at this point
Re: Rapsberry Pi cRIO Integration
Yes, but read the rules about additional electronics on the bot. Particularly rules about control of actuators.
You might find the Network Tables library useful for managing communication with the cRIO.
http://wpilib.screenstepslive.com/s/...client-pc-side
Mr Tim Klein
Code Guild Mentor
FRC Team 3966 STEMpunks
Unread 29-11-2013, 20:45
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Team 3946 used a RPi to do our visions processing/goal tracking last year. We created a Socket Server on the Pi in Python and a client in Java (that ran in its own thread as not to disrupt real-time functions if the connection was dropped).
All of our code is available here: UltimateAscent
The specific classes you would probably want to look at are ThreadedPi, ThreadedBerryPi under Subsystems, and PrintThreadPiData under Commands. If you want to look at the unthreaded version (also far less tested) the files are SocketPi, RaspberryPi and PrintPiData
Here is the code we were running on the RPI: PyGoalFinder
Good Luck!
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 01-01-2014, 22:47
tp2357 tp2357 is offline
AKA: Tyler Pawlaczyk
FRC #0340 (Greater Rochester Robotics)
tp2357 is an unknown quantity at this point
We experimented with this a bit last year, I was a fan of using I2C to communicate with the Pi, but I had to write an I2C slave driver to be able to implement that.
If you're interested, let me know and I can try to dig that up for you.
Java, Embedded C and LISP.
