Go to Post Yes, you are correct. Even when all other databuses are totally out of bandwith, the PainInTheCalf Bus gets top priority. Good thinking ;-) - Joe Johnson [more]
Unread 10-10-2013, 11:30
Dr.Bot
Posts: n/a
Suggested Programming Computer Platform
Our old IBM Thinkpad running Windows XP has finally given up the ghost (or at least lost some of the boot-up files.) I am wondering what people are using and happy with for a FIRST Java programming environment. Is Ubuntu/Eclipse a good way to go? What about dual-boot or VMs? If we go Ubuntu or Linux, what do we lose? I am guessing there are some programming tools that only will work with a Microsoft OS.
Thanks.
Unread 10-10-2013, 11:38
Re: Suggested Programming Computer Platform
Doesn't it have a recovery partition??
Unread 10-10-2013, 12:29
Dr.Bot
Posts: n/a
Of course it doesn't! I can try booting of a UNIX Stick drive, but I really am not into computer archeology.
Unread 10-10-2013, 12:36
I thought they all did that nowadays... except for the "fleet" machines which have been bulk re-imaged (like most of mine, which are mostly "rescue PCs" on which I have dual-installed Linux).
Unread 10-10-2013, 13:13
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Thanks.
My personal setup is a MacBook Pro dual-booting OS X and Windows 7. You can run NetBeans and do Java development on OS X (and presumably Linux), but as you probably already know the Driver Station and other tools (cRIO Imaging, Camera Setup, etc.) are only supported under Windows. I would avoid a Windows VM, as many have reported network issues when trying to connect to the robot.
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 14-10-2013, 13:28
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
krieck is an unknown quantity at this point
Java development works fine in MacOS and also on Linux. I do most of my work on MacOS. We have students running old machines on Ubuntu and Mint.
The main thing you give up is the driver station. None of us have been able to run that under Wine, although I've seen folks using Parallels on a Mac.
Unread 29-11-2013, 20:52
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
I did all my development last year in Netbeans on ArchLinux(with the Resource Hog known as Gnome Shell) with a Dual Core 2.2Ghz Pentium and the performance was great when I didn't have a million tabs open in my browser. I assume it would work equally as well on any stable OS on moderate hardware.
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 13-12-2013, 13:49
Bennett Bennett is offline
FRC #2977 (Sir Lancer Bots)
Bennett is an unknown quantity at this point
Our programmers use their personal Windows laptops with NetBeans.
Unread 01-01-2014, 23:07
tp2357 tp2357 is offline
AKA: Tyler Pawlaczyk
FRC #0340 (Greater Rochester Robotics)
tp2357 is an unknown quantity at this point
I'd say Ubuntu (or, if the machine is much older Xubuntu or Lubuntu) and Netbeans.
Netbeans is much lighter, and (I'm not sure if this is the case anymore) but Netbeans is officially supported by FIRST. I've never used Eclipse, but Netbeans also has great Git/SVN integration built in.
Java, Embedded C and LISP.
Unread 02-01-2014, 08:59
MichelB's Avatar
MichelB MichelB is offline
Jack Of All Trades
FRC #3941 (Absolute Zero Electricity)
Team Role: Electrical
MichelB is an unknown quantity at this point
We run several newer HP laptops on Windows 7 Pro, hopefully with a server-style version controll system. This seems to work good if you have several programmers working on the same code.
