Go to Post FRC: so inspiring, even car thieves can't handle it. - evanperryg [more]
Unread 29-11-2013, 22:52
yash101 yash101 is offline
AKA: null
Installing OpenCV
I have been having quite some trouble in getting OpenCV installed. After doing a quick search, "installing opencv," I got no good results. I have tried many of the installation techniques listed in various websites, found by searching, installing opencv. <<Hopefully, no one finds that offensive . Does anyone have a link to some good documentation on how to quickly install OpenCV? I am interested in compiling it, because I can use Git and get the latest code!
Unread 29-11-2013, 23:13
ad1217 ad1217 is offline
FRC #1786 (The Robotics Team)
ad1217 is an unknown quantity at this point
Re: Installing OpenCV
Question that will definitely help troubleshoot: What OS are you running?
Unread 29-11-2013, 23:28
AKA: null
Wink Re: Installing OpenCV
Currently Debian, however, I will switch to Ubuntu whenever possible. Ubuntu is basically Debian, with tons of add-ons!
Unread 29-11-2013, 23:58
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
If you used the install directions in the link you provided, you undoubtedly made it to this page.
Was there an issue with following those steps? I know it is written for Linux, but I followed it for Ubuntu and was successful. I believe it "should" work as well for Debien, as long as you compensate for any minor differences.
Unread 30-11-2013, 01:16
AKA: null
Yes. That is the first link that I clicked on. However, it does not include a comprehensive list of resources required by OpenCV. I want to have maximum compatibility, so I will make sure to get everything, even if I have to compile it myself! Also, that says,
cmake [<some optional parameters>] <path to the OpenCV source directory>
I do not know the optional parameters. I haven't messed around with CMAKE that much, so I do not know how to get the list of parameters.
Right now, I am following a tutorial on ozbots:
http://www.ozbotz.org/opencv-installation-2-3-1/http://www.ozbotz.org/opencv-installation-2-3-1/
Since that is for OpenCV 2.3.1, could that cause any faults?
Thanks!
Unread 30-11-2013, 11:30
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
This page, with instructions for opencv installation on debian, explains the cmake "optional parameters" a bit more.
http://team2168.org
Unread 30-11-2013, 12:03
hzheng_449 hzheng_449 is offline
AKA: Harrison Zheng
FRC #0449 (Blair Robot Project)
hzheng_449 will become famous soon enough
Also in Ubuntu 12.04 (which by the way is the LTS, so if you're gonna switch switch to 12.04) you can just apt-get the libraries (and of course it will also list out and allow you to install all the dependencies). This is what ended up doing since it's the easiest option...
link to apt-get installing opencv (the package may be slightly out of date)
On a slight tangent, I'm not really a fan of cmake, and if you aren't either, it's worth the time to google how to compile openCV projects with g++.
Unread 30-11-2013, 12:56
AKA: null
Smile Re: Installing OpenCV
That helps quite a bit. That article describes a little more on how to configure CMAKE. Right now, I am stuck on installing FFMPEG, because Apt won't download the current version of YASM (I have already run apt-get update). Currently, I am performing a distribution upgrade of Ubuntu, because I am running 12.04. Hopefully that will help! What webcam do you guys suggest for powerful vision tracking? I was thinking of a camera with a high shutter speed, low ISO, and high aperture. That would allow me to set up a spotlight of light, to be retroreflected to the camera. The camera would only be able to capture that bright light!
I agree. I am not a fan of CMAKE either. I was just going to use an IDE like Netbeans! That would get rid of all the confusion, caused by setting up! I will google about how to compile OpenCV projects using g++. I believe it uses PKG-CONFIG, so it shouldn't be rocket science!
PHP Code:
While compiling OpenCVat 20%, I got this error:
20%] Building CXX object modules/highgui/CMakeFiles/opencv_highgui.dir/src/bitstrm.cpp.o
20%] Building CXX object modules/highgui/CMakeFiles/opencv_highgui.dir/src/rgbe.cpp.o
Linking CXX shared library
../../lib/libopencv_highgui.so
/usr/bin/ld: /usr/local/lib/libavcodec.a(avpacket.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/usr/local/lib/libavcodec.a: could not read symbols: Bad value
collect2: error: ld returned 1 exit status
make[2]: *** [lib/libopencv_highgui.so.3.0.0] Error 1
make[1]: *** [modules/highgui/CMakeFiles/opencv_highgui.dir/all] Error 2
make: *** [all] Error 2
Does anyone know what it could be?
Unread 30-11-2013, 21:51
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
While no build system is perfect, CMake does a good job of managing cross-platform building. I wouldn't dismiss it too readily. But we digress.
PHP Code:
Based on what I'm reading here, I'm inclined to think that OpenCV is having issues on the AV codec for it's internal HighGUI library.
Are you using parallel builds with make? That might explain it -- this step could be dependent on another step that has not been completed yet.
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Unread 30-11-2013, 23:39
AKA: Harrison Zheng
PHP Code:
I'm pretty sure I got a similar build error when I was installing openCV(which was around September). Hopefully Brennon's suggestion works, if not try building an older version of openCV or do the "lazy" thing and apt-get the library (which is what I ended up doing).
Unread 01-12-2013, 00:16
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Since you said you were going to switch to ubuntu...here is the "master list" a mentor and I came up with 2 years ago:
sudo apt-get install synaptic
sudo apt-get update
*sudo apt-get install qt4-dev-tools libqt4-dev libqt4-core libqt4-gui
*sudo apt-get install qtcreator
sudo su
sudo apt-get install build-essential
sudo apt-get install libavformat-dev
sudo apt-get install ffmpeg
sudo apt-get install libcv2.3 libcvaux2.3 libhighgui2.3 python-opencv opencv-doc libcv-dev libcvaux-dev libhighgui-dev
**apt-get install freenect
*install qt creator, an IDE (integrated development platform)
**for kinect
we used these exact steps for our O-Droid XUs we got 2 weeks ago and all are running vision programs without any problems.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 01-12-2013, 13:09
AKA: null
I did try to build many of the things like x264 and ffmpeg, and whatever I couldn't find in the apt repository, myself, from the git code! I think that I may be using too current of a code! That could be why I am having many of these problems!
I think it would be wise for someone (maybe me), to create an install script, to install every package from Apt, and then download source from git to build!
Unread 01-12-2013, 13:21
Free Agent
Might be a bit late, but this is the official documentation from OpenCV with regards to building on Linux. Unless you plan on working on OpenCV itself, I'd stick with version 2.4.7, which is the latest stable version.
EDIT: As of 11/11/13, the latest version of OpenCV is 2.4.7.
Last edited by brennonbrimhall : 01-12-2013 at 15:48. Reason: Corrected latest version of OpenCV
Unread 01-12-2013, 13:26
AKA: null
It's not too late. I just need to redownload OpenCV and reconfigure it. Just a half hour, maybe. I have succeeded at building OpenCV from git before, but I do not know what is different this time. Let me make sure that I have properly installed LibAVCodec!
BTW, Brennon Brimhall, Thanks for the quick reply!
EDIT:
I just booted Ubuntu and checked the libavcodec installation status and found out that it wasn't properly installed. I forgot libavcodec-dev, but installed libavcodec-53! Now, let me retry the build, and hopefully I won't encounter any problems!
The build is still failing continuously. What do I do? I have uploaded a txt file with the output, created by make | tee dev_build.txt
I have tried re-installing libavcodec-dev libavcodec53 libavcodec-extra-53 but the problem persists. Should I compile it myself, or should I get a different mirror, update my system, or am I downloading a completely wrong package?
UPDATE:
I am compiling the code in the fashion that Brennon suggested, downloading the latest stable build from SourceForge. Currently it is compiling. I will include a build log, build_log.txt.
Thanks for your help
Unread 01-12-2013, 18:05
AKA: null
It seems as though maybe the libavcodec package may be broken . That is what is stopping me from having a complete build!
