Go to Post Remember this: A true leader needs no title to make a difference. - Molten [more]
Go Back   Chief Delphi > Announcements
  #31   Spotlight this post!
Unread 30-11-2013, 18:29
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Anti-Spam Plugin Installed
Good idea. Not sure if this version of VB has a plugin that can inspect the number of links. That would be good, though - perhaps limit all posts to 4 links or less.
I can believe the spam issue is just another reason to move to the latest version of VB. Meanwhile, we can play the game too....
  #32   Spotlight this post!
Unread 30-11-2013, 18:45
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Anything to cut down on the spam. Maybe the number of links cannot be greater than 1/10th of the poster's reputation?
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
  #33   Spotlight this post!
Unread 01-12-2013, 23:30
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
This would work if rep was more readily given out by users. For people like me with nearly four years as an active user but less than ten rep, links would be off-limits.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
  #34   Spotlight this post!
Unread 02-12-2013, 12:31
CD was down for me for about 4 hours. Was there an update?
  #35   Spotlight this post!
Unread 02-12-2013, 12:36
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Memory issue with mysql and some server monitoring software. Should be better for now.
Brandon Martus
e-mail
  #36   Spotlight this post!
Unread 02-12-2013, 19:05
yash101 yash101 is offline
AKA: null
Talking Re: Anti-Spam Plugin Installed
Why were you getting those problems? Are you using the default configuration or did you reconfigure MySQL? On my server, I use the default configuration, and I am able to spam it with AB, without getting these problems! You may want to try running AB from a different vHost from the same hosting provider, and stress-test CD. That will give areas of strengthening to you
  #37   Spotlight this post!
Unread 07-12-2013, 21:52
AKA: null
Either I am not accessing CD as much these days (Cause finals are coming), or there has been a massive reduction in spam! Is it the recently installed plugin, SFS blocking these spammers or is it something else, like: Spammer thinks to himself, It's Christmas (Almost), so let me give Mr. Martus a break!
  #38   Spotlight this post!
Unread 08-12-2013, 00:07
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Might be a bit better, there is still a fair amount. Part of it is likely due to moderators quick response to reported threads.
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
  #39   Spotlight this post!
Unread 11-12-2013, 21:07
AKA: null
I think that is is a combination of both. Both, the antispam plugins, and the user group, along with Mr. Martus are the reasons behind the little spam on this forum!
  #40   Spotlight this post!
Unread 29-12-2013, 21:57
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
From a lay person's perspective, the level of spam on CD has gone down significantly. A much, much, much better experience overall, and just in time for kickoff! Thank you Brandon M. and the team of mods for everything you do!
Thought it was worth celebrating a particular success in our community
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
  #41   Spotlight this post!
Unread 29-12-2013, 23:13
AKA: null
Are there any other plugins that have been installed?
If there aren't, I think it is just old spammers who already created an account who are able to spam. By the way, Brandon, do you delete the spam users, or just the post/thread?
Other than that, I have noticed that nowadays, very spam threads are going around. Maybe Mr. Martus is getting faster, or the spam plugins are resolving just in time for Christmas, New Years and Kickoff (Thankfully).
Just for the sake of it, I still think that the occasional spam thread is all right if deleted a couple hours later because it allows us to grab a laugh at all the grammer errors they make
  #42   Spotlight this post!
Unread 08-01-2014, 23:02
CRITICALThinker's Avatar
CRITICALThinker CRITICALThinker is offline
New user, first time FRC
FRC #5064 (Opcom Robotics)
Team Role: Electrical
CRITICALThinker is an unknown quantity at this point
Hi, this is my first post on this forum, and I wish to thank the creator of this forum for creating this resource. I am part of team 5064, and am trying to get my team to sign up. One of my friends on the team attempted to sign up for the forum, but got flagged as a spammer, he has sent an email, but from my current knowledge it has not been responded to.
thank you fro reading this post, and I hope this can be fixed soon.
  #43   Spotlight this post!
Unread 08-01-2014, 23:28
AKA: null
Has he tried from a different IP? Tell him to try a web proxy, temporarily. I think you should be able to log in with an account already created, from a blocked area. Otherwise, I think you could try making the account for him and letting him sign in and change the password.
  #44   Spotlight this post!
Unread 13-01-2014, 18:53
Thanks for the suggestions(I have a feeling he was using a proxy at the time), but he has managed to get a hold of the forum administrator(?) and got an account.
