Thread Tools |
Rating:
Display Modes |
Re: [FTC]: Tetrix motor controller weirdness with 4 motors
Once it was faulted, the problem would remain regardless of program running (or not running) on the nxt. |
ak,
This sounds so much like an over current issue with four motors running. When you add up the motors, the reversing as a repeatable cause and reboot to clear the problem, it seems like everything is pointing to the motor loads dragging the battery voltage down. The inductor used in the previous motors was under rated for current such that repeated stall current would eventually burn open the inductor. This does not sound like RF interference as that would produce more problems and generally be not repeatable. RF is at it's highest while the motor is running wide open or under heavy load. Last edited by Al Skierkiewicz : 01-12-2013 at 18:21. |
But I would also agree that my explanation, (RF issues) is unlikely. Not knowing the root cause puts our "fix" in the realm of voodoo and that is particularly unsatisfying. |
I would pull the motors out of their mounts and make sure they are all spinning the correct way. As Al said, it sounds like an over current issue. I have seen it where one of the motors on a side is shorting, putting into a break mode, so it causes the other motors to work harder to overcome the motor that's not spinning.
Otherwise I would rewire everything and make sure there are no shorts. I would advise not daisy chaining the electronics on the robot, I have all my teams use Anderson Power Poles or Wago Levernuts, so if there is a wiring issue, everything down line doesn't go down. Especially since the voltage sensitive Samantha module is always the end of the line in the daisy chain wiring scheme. |
ak,
I went back and read over your post again. Am I correct that you have one controller feeding all four motors? Is that one controller output or two motors on one output and two on the other output? The motor controller is intended to power only one Tetrix motor per output. The controller has over current sense and will shut down if the current is too high or the temperature climbs above a certain point. If the controller is shutting down for a fault, it may fail to pass I2C signals on to the following devices. The specification sheet lists the current output for each motor circuit at 4 amps which is below the stall current for the motors. |
I do have a question,
What is the purpose of running four motors off one controller? There is no limitations to how many DC motor controllers you may have, the limitation is being only allowed to have 8 motors. Last edited by orangemoore : 02-12-2013 at 18:59. Reason: Wrong information. |
#7
http://ftcforum.usfirst.org/showthre...ull=1#post7575
2 motors per port has always worked just fine and is allowed. However, we have not yet done it with the new motors. Is anyone else using 2 motors per port with the new motors? |
#8
4 motors on one controller worked fine for us with the new motors at our first Qualifier.
Don't confuse FRC and FTC. There is nothing in the FTC rules preventing 4 motors on one controller. Also, from the LEGO Education site: http://www.legoeducation.us/eng/prod...or_tetrix/1648 The HiTechnic DC Motor Controller for TETRIX® connects to an NXT Intelligent Brick sensor port and will enable you to control powerful DC gear motors for use with TETRIX robots. The controller has two H-bridge outputs to control the speed and direction of two DC gear motors and is designed to connect to the TETRIX hole pattern. A four-motor robot can also be built by paralleling two motors to one channel. A total of four DC Motor Controllers for TETRIX and/or Servo Controllers for TETRIX can be daisy-chained to provide additional motor and/or servo outputs on each port. --Scott |
#9
We have our qualifier this weekend that we'll run with our current setup and then return to troubleshooting after the event. Lots of suggestions of an over-current fault but that seems inconsistent with the applied load. When we return to troubleshooting I'll instrument the controller and see what our current actually is. |
#10
ak,
I received some info that the I2C passes through the controller in the event of a fault. So if you are having issues down stream from a particular controller, that device could have an issue or you could have a defective cable. However, there is still the off chance that one of the drive motors has excessive friction causing some high motor currents. You need to isolate the motors and see if you can find that issue as well. You mentioned in your first post that the motors are mechanically coupled, so it is possible that one of the motor issues is being coupled into the other. If you remove one electrically the mechanical problem still exists. Good luck this weekend. |
#11
So, continue down the overload diagnostic path. I'd consider swapping out that motor controller. It's possible that it has a partial failure that prevents if from dealing with a full over-load. Phil. |
#12
Are you making your two motors per channel connection in the controller itself? IF so, having eight wires in such a crammed space can be your problem. It does sound like excessive current. If the motors are not under load, and it's still happening, make sure you are not shorting the wires right at the controller. We have had that happen several times.
#13
I believe I am seeing the same problem. I think the new v2 motors are the root cause.
CONFIGURATION: Code:
#pragma config(Motor, mtr_S1_C1_1, LeftMotor, tmotorTetrix, openLoop, encoder) #pragma config(Motor, mtr_S1_C1_2, RightMotor, tmotorTetrix, openLoop, reversed) #pragma config(Motor, mtr_S2_C1_1, FlagMotor, tmotorTetrix, openLoop) #pragma config(Motor, mtr_S2_C1_2, LiftMotor, tmotorTetrix, openLoop) TEST #1: LeftMotor: v2 Tetrix DC motor RightMotor: v2 Tetrix DC motor FlagMotor: ORIGINAL Tetrix DC motor LiftMotor: v2 Tetrix DC motor Robot drives just fine, low to max power, forward and reverse. FlagMotor is also fine. No surprises. However, whenever you run LiftMotor (the third v3 motor in the set) for more than a few seconds, the NXT "loses connection", the downstream servo controllers go ape, and everything freezes, requiring a hard boot of the NXT and usually ROBOTC. I've tried various changes in pragma (daisy chain, parallel, swapped the controllers...) to no effect. I have not tried swapping the order of the motors in their sequence. TEST #2: LeftMotor: v2 Tetrix DC motor RightMotor: v2 Tetrix DC motor FlagMotor: Original Tetrix DC motor LiftMotor: ORIGINAL Tetrix DC motor NO CRASH! Everything seems to run just fine with one of the original motors as the fourth motor. In fact, I can run all four motors simultaneously at max power, forward and reverse like a madman. Now my problem is this: As a rookie team, we were shipped four of the original motors with the plastic gears in our KOP. LEGO Education recently sent us 4 v2 motors as replacements. We have not received our "gear replacement" kits. Our LiftMotor probably cannot be relied on as a plastic gear motor. Should I swap the metal gears from one of our v2 motors into our original plastic gear motors? WHAT A MESS. We've also been unable to get an encoder to work so we're having to run open loop in autonomous. Advice on that problem is we got a bad encoder. Our first competition is next Saturday and we can't even get past our basic motor usage due to problems created by the exclusive vendor's failure to manage their supply chain. I imagine you guys have been living with this for years but as a rookie coach I find this especially shocking. I am in a near panic at this point. The team has worked so hard and mechanically our robot is finished. However, we'll be lucky at this point to show up with a robot that does little more than drive. Last edited by F Elliott : 05-01-2014 at 19:00. |
#14
I tried swapping order of the motors. Order doesn't seem to matter. Two total v2s on two motor controllers (combined or split) works fine. Add a third v2 to either controller and kaput.
We do not have a third motor controller or I would try it. We are going to use a plastic gear original motor and hope for the best. Sigh. |
