Go to Post I want an inflatable playing field so 2 people can setup the competition in one hour at every event. I want it to fit in the back of my car. - Ken Leung [more]
Unread 02-12-2013, 15:24
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: Robonauts CAD
Maybe I'm missing something, but how did you get your chain in there?
You drop the chain and sprockets straight into the tube from one end. Then, while the sprockets are approximately in position, you slip your shaft into place and put the backside bearing in.
We ran this setup all year without maintenance.
221 Robotic Systems is launching a production version based on this design for 2014. Personally I loved the space we gained back by moving the chains inside and the weight saved by removing the tensioning device.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 02-12-2013, 15:33
Chris is me's Avatar
AKA: Pinecone
Re: Robonauts CAD
Wow, I did not think internal chain like that without tensioner a was even possible. I can't believe the chain never stretched or loosened. The space savings over internal timing belt (not to mention cost) means my team will have to seriously consider this as an option for 2014.
Unread 02-12-2013, 15:40
AKA: Anthony Lapp
Re: Robonauts CAD
I'm sure it did loosen over time...likely due to sprocket wear. However, it can't go anywhere. It would have to eat away the tubing to jump off.
FYI...I'm quite sure FRC233 has been doing this for a while. There may be others too.
Anthony Lapp
RobotOpen
Unread 02-12-2013, 18:11
smistthegreat's Avatar
smistthegreat smistthegreat is offline
robots is a hard job
AKA: Brian Smist
FRC #4930 (The Electric Mayhem)
smistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond repute
Re: Robonauts CAD
340 has been doing it for the past couple of years too.
University at Buffalo | Mechanical Engineering | Class of 2016
2014-20?? | Mentor | 4930 | The Electric Mayhem
2013 | Mentor | 229 | Division by Zero
2013 | Mentor | 4124 | Integration by Parts
2009-2012 | Student | 1507 | Warlocks
Unread 02-12-2013, 18:16
Re: Robonauts CAD
It was definitely cool to see at IRI, and just made quite a lot of sense. I was surprised to have not thought of it before.
PS - I always tell this to people who ask me about 118, but Anthony gives THE BEST robot tours. I look forward to it each time I see them.
Thanks for the CAD!
Unread 04-12-2013, 18:03
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Re: Robonauts CAD
In the unlikely event of a chain breakage, how long would it take to replace the chain?
2016: FRC 865 Mentor
Unread 04-12-2013, 18:19
AKA: Anthony Lapp
Re: Robonauts CAD
Theoretically it should be impossible to generate enough traction at the wheel to overcome the tensile strength of the chain.
That said, it didn't look plausible to us to replace a chain in the heat of battle.
So, to give ourselves comfort we built a complete chassis in the pre-season to test the setup. This included stress testing the chains by continuously going between max forward and reverse torque. We survived this testing without incident.
Both the practice bot and comp bot went the whole season without a blown chain. Once I recall we had a chain jump the sprocket and jam...this was determined to be cause by a rivet body that had made its way under the chain and sprocket....it was resolved without removing any parts.
Anthony Lapp
RobotOpen
Unread 04-12-2013, 21:04
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Does anyone sell that double sprocket as an off the shelf item or is that custom?
Unread 04-12-2013, 21:08
BurkeHalderman's Avatar
BurkeHalderman BurkeHalderman is offline
Casual Robot Observer
BurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant future
Re: Robonauts CAD
It is custom, but I believe 221 Robotics Systems will be offering it separately with a keyed bore.
[2010-2014]: FRC 3266 Robots-R-Us: Founder and Alumni
2010 (5-5-1): Buckeye Regional; Driver
2011 (4-5-0): Buckeye Regional; CORI; CAGE Match; Drivetrain/Manipulator Operator
2012 (7-13-0): Buckeye Regional; Queen City Regional; CAGE Match; BPRC; Drivetrain Operator
2013 (25-15-1): Queen City Regional; Buckeye Regional; Crossroads Regional; CORI; Ohio State Champs; CAGE Match; BPRC; Drivetrain Operator
2014 (21-10-0): Crossroads Regional; Queen City Regional; Designer; Mechanical/Design Mentor
Founding an FRC team as an 8th grader sure wasn't easy, but it was totally worth it.
Get in touch with me:
Personal Facebook
I believe every human has a finite number of heartbeats. I don’t intend to waste any of mine. – Neil Armstrong
Unread 04-12-2013, 21:33
AKA: Anthony Lapp
Re: Robonauts CAD
Soon.
SimpleTube Chassis System
Anthony Lapp
RobotOpen
Unread 04-12-2013, 21:44
Re: Robonauts CAD
Any idea when the sprockets will be available?
Unread 04-12-2013, 22:03
AKA: Anthony Lapp
Re: Robonauts CAD
The whole chassis system and it's accessories are scheduled for kickoff weekend.
The current plan is to offer all of our popular transmission options, 6wd, 8wd and several size options.
Anthony Lapp
RobotOpen
Unread 05-12-2013, 17:02
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
Re: Robonauts CAD
Looks like the 2013 robot and the SimpleTube chassis don't have the center pair of wheels dropped - how are you avoiding wheel scrub during turns? Looks like all of the 118 wheels are the same dia - do the custom wheels have a low lateral CoF?
Unread 05-12-2013, 17:59
AKA: Anthony Lapp
Re: Robonauts CAD
The Robonaut wheels were not the same diameter. The outer wheels were approximately 1/2" smaller in diameter. The CAD may not reflect this.
The internal geometry of the double sprocket does not allow for any drop.
SimpleTube will use this same arrangement of different sized wheels.
Anthony Lapp
RobotOpen
Unread 05-12-2013, 21:16
Answer42's Avatar
Answer42 Answer42 is offline
Answer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud of
Re: Robonauts CAD
Does that difference in wheel size cause faster wear on the wheels because of difference in speed? I ask because I noticed 118 had a lot chunks taken out of their wheels at SVR before they replaced them.
