Go to Post Beware of the following: boredom intelligence = ??? <- could be anything... - JBotAlan [more]
Unread 02-12-2013, 18:56
yash101 yash101 is offline
AKA: null
Robot Tips For Rookie Teams
I wanted to create a thread of tips for rookie teams to think about to improve on their robots. Build season is rapidly approaching and I haven't seen a single thread about tips and tricks to help teams. Some examples of things that would be worth mentioning would be like:
-Low Center of Gravity
-Don't overcomplicate things
-Ectetera...Whatever y'all think would be worth mentioning!
Unread 02-12-2013, 19:01
rwkling1's Avatar
rwkling1 rwkling1 is offline
FRC #2977 (Sir Lancer Bots)
rwkling1 has a spectacular aura aboutrwkling1 has a spectacular aura about
Re: Robot Tips For Rookie Teams
Like you said, don't overcomplicate things, that would be my biggest tip. The problems we've had in the past is that we've tried to do things that just weren't realistic for how old our team was. Also, prototyping is a very important stage, make sure that it's decently consistent before moving on to the final.
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
1. Good Bumpers!!!!!! Actually use the material FIRST recommends (I think it's condura or something like that)
2. Make sure you learn to download your code correctly
3. Have a good pit designed before going to your first event
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 02-12-2013, 19:23
Whatever the size FIRST gives for the robot, build 1" under. Not design, build. Somehow, the robot will gain that inch back.
Ditto for weight: build 10# under (accomplished by designing 15# under). That way, you'll come out right at maximum--though having to grab a block of steel might be necessary.
Aim for the simpler tasks. Particularly if you don't have a lot of expertise. Sometimes, a lockdown robot that can score lots of 1-pointers can be worth more than a high-point robot that only works half the time.
Unread 02-12-2013, 19:27
wasayanwer97's Avatar
wasayanwer97 wasayanwer97 is offline
Take from the best, invent the rest
AKA: Wasay Anwer
FRC #0668 (The Apes of Wrath)
wasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant future
First off, to any rookies who may end up reading his, welcome to FIRST. It's going to be one of the best things you will experience in your time as a student. People on this forum are here to help, so don't be shy to ask for it. (Search for a previous thread on it first though.)
As for tips:
Keep it simple.
Many people have already stated it, and it can't be stated enough.
Other pieces of advice (for a rookie team):
1. Use the KOP. I've seen a fair share of team, even veteran ones, who try to build their own drive train and end up with one less competent than the KOP. The KOP may not necessarily be the best, but it's reliable and allows you to focus on your mechanisms .
2. Read the manual. Take it seriously, the last thing you want is to find out you come in conflict with the rules at competition. Make sure you give yourself a practice inspection before bag.
3. Make components (relatively) easy to replace. Things break. Accidents happen. You'll save yourself a lot of headache if things like motors, motor controllers, and wires are easy to access. Access holes/points are key.
4. Design within your limits. Don't design a robot you can't build or afford. Know what your team can and can't pull off. It wouldn't be very wise for a rookie team to do a swerve drive, for instance... Also, do order parts you think you will need ahead of time. Things go out of stock pretty fast during build season.
I'll post more later if I think of some.
"Coming together is a beginning; keeping together is progress; working together is success."- Henry Ford
FRC Team 668: The Apes of Wrath
Pioneer High School, San Jose CA
http://www.theapesofwrath.org
Talking to other FIRSTers is great. Add me on Facebook!
My Page
Unread 02-12-2013, 19:28
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Ask questions before it is too late
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 02-12-2013, 19:56
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
A lot of teams start their brainstorming on Day 1 diving headfirst into how they might make various components on a robot. You might make a bunch of excellent robot parts, but without a well thought out strategy that robot will inevitably be playing inefficiently.
A good guideline is to leave robot part discussion off the table for at least the first day or two. Use this time to have every single team member read every line of the rules. Then, discuss how to play the game. Keep track of every idea (sticky notes and whiteboards are great for this) because even ideas that don't work can cause someone to think of something brilliant. No side conversations for the same reason.
You should be discussing how the robot is scoring points, what you think other robots will do, and how to fit yourself into an alliance (always remember that you can't do everything yourself). Look for choke-hold strategies, though there often may not be one. Once you know what the robot needs to do, you can figure out what parts are needed to achieve that.
Also, my pet peeve: don't worry about pushing matches. If you're on offense, pushing against a defender is exactly what they want you to do. If you push, you waste your time. Time is points, so instead try to avoid or evade defenders. If you're on defense, your wheels should be perpendicular to the path of your opponent, so there should be no need to push.
Unread 02-12-2013, 20:02
AdamHeard's Avatar
Lead Mentor
With the new perimeter rules the 1" under issues is much less severe.
Unread 02-12-2013, 20:27
chmorroni chmorroni is offline
chmorroni
AKA: Christopher Morroni
FRC #3729
chmorroni is on a distinguished road
Pick one thing, and do it well.
Last year, our failing point was trying to design a robot that could do everything. We wanted it to have a 50-point climb and a full-court shooter. We didn't have our final climber built until the day of bag-and-tag. 3 hours before the deadline, in our first test of the mechanism, the cables broke, and we realized that the design wouldn't work. Our shooter, designed to be on top of a robot with a low CoG, did not work as a FCS because we had to turn the robot around after loading 3 disks, to fire the shooter.
Also, know the rules by heart before the second day. The night of kickoff, the game rules are your only companion until you know them backwards and forwards. This goes for every member of the team. That said, always have a copy of the rule book handy for rule checks and other references, especially during the design process. Before you even start designing and prototyping an idea, make sure it is within the rules.
It is also best if you make diagrams and drawings of some of the rules for the robot (size, weight, wire gauges, etc.) for quick reference during the designing and building of the robot.
Also, leaders and older members, delegate, delegate, delegate. You should never have idle hands/minds at meetings. There is always something that needs to be done, so, if there is someone standing around, either you need to take a step back and let someone else do what you are doing, or you need to find something for them to do. Have a list of random jobs going into a meeting, so you can assign them to idle people.
Teach new and young members, and have them work on the robot a lot! If you have a lot of seniors that do everything, there will be no one next year that know what they are doing. On top of that, what is the point of joining a robotics team if you don't get to do anything. It is a learning experience for everyone, so let it be just that.
Unread 02-12-2013, 20:38
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
#1 Read the manual, cover to cover.
#2 Read the manual, cover to cover.
#3 Read the manual, cover to cover.
Unread 02-12-2013, 20:44
chmorroni
FRC #3729
#4 Repeat steps 1-3
Unread 02-12-2013, 20:45
Quite true. OTOH, it's always a pain to arrive and discover that you're out of compliance by -><-. I've seen that a few times... and it's never fun to tell a team that they are out of compliance by dimension.
As far as the rules-reading goes, I've got a couple of things...
-There is no unimportant rule. (And, for those wanting to get a head start, the Administrative Manual has been released already. Some of those "Can we use X at the event?" questions are already answered.)
-Read ALL the Updates issued. They change the rules, sometimes significantly.
-Read ALL the Q&A. Most of it won't necessarily apply to you--but the items that do can be pretty important.
-If it has a rule number, it is not a suggestion. If it's in a blue box, it's explanation for that requirement, or clarification of it.
Oh, and one more tip for all rookies: Bring a wheeled conveyance for your robot and driver's station, marked with your team number. Your arms and legs will thank you for the wheels; the queuing staff will thank you that they can return it to you easily.
Unread 02-12-2013, 20:49
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Originally Posted by wasayanwer97 View Post
...Other pieces of advice (for a rookie team):
With out a doubt, this is the best advice in my estimation. To add to that, build it and have it running within the first week before you worry about scoring mechanisms.
David
Unread 02-12-2013, 20:52
AKA: null
I can think of a few:
-Show GP at the competition
-Don't drive behind success. Do your best and success will dive behind you!
-Show great sportsmanship. After all, FIRST is a "Sport," AKA, the "Sport of the Mind." We build robot athletes to participate in the sport, released on the Kickoff!
Unread 02-12-2013, 21:05
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
Here's a presentation Mike Corsetto and I gave to our team just a couple months ago. Should give rookie teams a good place to start.
https://www.dropbox.com/s/tp700bu4l9...0workshop.pptx
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
