Go to Post I've worked with space based navigation and lever arms and planes and Kalman filters. .. and I have never, ever once considered looking up to navigate. - purduephotog [more]
Unread 08-02-2003, 23:18
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
Making a Dongle - Pin 1 help
Hey-o.... I'm trying to make a dongle for our system.
Joe Johnson's dongle whitepaper shows the Disable pin and pin 1 being switched to ground (with the more-channels pin permanently shorted). An LED is lit up through Pin 1. IFI doesn't list anything about Pin 1. I'm assuming that Joe found out Pin 1 supplied an output voltage of some amount, and so he used that to power the LED. But, that dongle whitepaper is a few year(s?) old. So, my question is this: does pin 1 on the competition port still supply an output voltage that you can use to light up an LED?
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 08-02-2003, 23:27
n[ate]vw's Avatar
n[ate]vw n[ate]vw is offline
#0933 (Adler Attack)
n[ate]vw is an unknown quantity at this point
Send a message via AIM to n[ate]vw
I would assume so. Wasn't it working?
[edit]Put a voltmeter between ground and pin 1[/edit}
Adler Attack #933 -- Trigos
Unread 08-02-2003, 23:54
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Be careful with Pin1. I've heard rumors that it is the pin used to get power to the OI during competitions, so it probably interfaces directly with much of the internal circuitry.
Unread 09-02-2003, 00:23
Crusty Mentor
FRC #0097
Yeah, I just saw many warnings about touching things like that, so I wanted to see if anyone had any expierience with making a dongle this year before I went and did that.
Dan L
Team 97 Mentor
Unread 14-02-2003, 03:19
You can power the OI through pin 1, it is connected to the +9V input on the input jack from the Wall Wart.
The light in the Classic Yellow Dongle only works when powered by the Wall Wart, though. It will not light when operating on tether, where the power is supplied up the tether cable from the 'bot-terry.
Unread 05-03-2003, 12:04
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
ME HELP
WE HAVE TWO DONGLES!
Give me an adress and ill send one
Unread 05-03-2003, 16:58
Crusty Mentor
FRC #0097
Thanks, but I've made one since I made this post:
http://www.chiefdelphi.com/forums/at...&postid=135152
Save it for another team that needs one =D
Dan L
Team 97 Mentor
Problems with a pin... randomperson Electrical 2 09-02-2003 23:44
yellow dongle Ryan Foley Electrical 1 24-01-2003 15:41
Ugh...PWM pin vs. Speed Controller archiver 2001 1 24-06-2002 00:27
Diagrams for wiring of 15 and 25 pin connectors archiver 2000 2 23-06-2002 23:03
PBASIC access to 1 pin only diego25 Programming 13 21-01-2002 10:55
