Go to Post I think it will be very hard to find one aspect of FIRST which doesn't inspire us. - Arefin Bari [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 03-12-2013, 15:58
Thoughted Thoughted is offline
FRC #4158
Thoughted is an unknown quantity at this point
ERROR When trying to run test code
Whenever we try to run the test code that our programming teacher made for us it gives us an error saying "Connection failed. The network address might be invalid or the target is not responding." Anyone have any experience with this issue. Sorry we are new to LabView.
Unread 03-12-2013, 16:24
jlmcmchl jlmcmchl is offline
FF - The Breakfast Company
AKA: Jordan McMichael
FRC #0027 (Team RUSH 27)
jlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud of
Re: ERROR When trying to run test code
This looks to be a networking error.
Is everything plugged in and turned on? Make sure you have connected to the robot via wireless or ethernet cable. Networking should be turned on, on the computer, and the robot's router should be set to bridge mode.
Field reset: Kettering Kickoff ('13, '14), Kettering ('14, '15), Bedford ('14), Woodhaven ('16), Carver ('16), Einstein! ('16)
Referee: Bedford ('15), MARC ('15, '16), Kettering Kickoff ('15, '16), Kettering District (#1&2: '16), Troy ('16)
Unread 03-12-2013, 16:29
1) How are you trying to run the code? Be specific.
2) Is the IP address associated with the Real-Time target correct? (It's in parentheses, and should probably be in the format 10.te.am.2 where te.am is your team number split in two-digit pieces.)
